Thanks everyone for your comments.
Galifridus, thank you for the purchase :)As Galfridus, pointed out you don't have to have the toon figure set to use the facial expressions. I tested it with the Kevin character, before publishing it and it worked perfectly.
Galfridus, you simply have to send your character to iClone from CC4, once you applied the Ultimate expressions.
The new expressions will be found under the FACE KEY tab inside iClone.
To access this tab
1. Open the Animation tab, then
2. The click on the "Face KEY" tab,
3. Inside the face key editor window select the "Modify" tab.
4. Inside the Modify window you will find all your face keys, including the custom ones,
5. Open the custom tab (near the bottom) and you should see the 140 Ultimate expressions sliders.
Unlike CC4, iClone does not feature the reference images next to the slider but you can either do a search for the following categories -
* "positive" - for all the Positive Expressions
* "negative" - For all the Negative Expressions
* "mouth" - For the mouth only expressions
* "eyes" - For the eye expressions only
* "brow" - For editing the brows
" "eyelashes" - for editing and manipulating the eyelashes.
* "face" - to bring up the four face shape morphs
* "unconscious" - To bring up the expressions for breathing and other unconscious actions; or
* "set" - to bring up all the facial parts you can tweak to correct the expression, like the brows, lashes, lips, etc
Otherwise, I attached.
a) The entire list of expressions (with images) and a
b) A Comprehensive Reference sheet in the order they appear, make it easier :)
Happy animating :)
