K_Digital
K_Digital
Last Active: 3 days ago
Visits: 1.4K
Hello,
Downloaded models from scetchfab seem to be in zip files, containing two folders source and textures. Source contains a model fbx or obj for example, but when loading this into accurig i dont get the textures, always a white blank model.
Question: where do i need to put the textures from the texture folder in order for accurig to load them together with the model ?
Thanks in advance
Posts: 23.1K,
Visits: 36.6K
Hi... Can you provide a link to one of the models you downloaded so we can check it. Thanks.
K_Digital
K_Digital
Visits: 1.4K
Posts: 23.1K,
Visits: 36.6K
Thanks for supplying the links. When you download an OBJ model it comes with an accompanying .MTL file which contains the location of the models textures. So when software like AccuRig opens the model it will look at the .MTL file to find the textures. The problem with the Sketchfab models you linked to is that the MTL file has the wrong file format and location which is why AccuRig can't find the textures. For the character model below I have fixed the .MTL links so it will load correctly now in AccuRig. The corrected file is is attached. Just download, unzip and open the OBJ in AccuRig. 75% of original size (was 669x19) - Click to enlarge
K_Digital
K_Digital
Visits: 1.4K
Oh, THANKS !
Easy to fix, havent noticed that .MTL.
