Problems with motion loops.
Posted By bad_character 2 Years Ago
bad_character
bad_character
Veteran Member (532 reputation)Veteran Member (532 reputation)Veteran Member (532 reputation)Veteran Member (532 reputation)Veteran Member (532 reputation)Veteran Member (532 reputation)Veteran Member (532 reputation)Veteran Member (532 reputation)Veteran Member (532 reputation)
Posts: 75, Visits: 563
I have a miximo running animation and I’ve looped it. For some reason, while the first segment stays on the ground, the next three progressively rise up in the air.
I’ve tried to use motion direction control to bring it down level, but that always immediately crashes iclone. I assume it’s not compatible with loops.
So instead I’ve tried to disable ik on the feet and bring the runner down using hip translation. I can’t do either of those steps though, because it says “can’t set key frames on a motion loop, please flatten the motion clip and try again”. Flattening or sampling makes no change to that message preventing any key frames though. It will bring up keys or flatten them in the first segment, but it doesn’t get rid of the loop or allow you to set key frames.
So the question is, is there some way to flatten a motion loop?
