nonorthstudio (9/5/2024)
i tried this step and cannot log on. it says i need to reset my pac. i followed the directions and everything is good and i can't use it. I'm not sure what you mean by "i followed the directions and everything is good and i can't use it."
Can you now login to the Hub or are you still having login issues? If you can't login, then you may need to reset the Password as shown below. If you can login to the Hub then please explain what the problem is with using the Hub. Thanks.
