CC keeps crashing during rendering!
Posted By COLINMAC2 3 Years Ago
COLINMAC2
COLINMAC2
Posts: 122, Visits: 143
I've done several other video renders with no problem, but suddenly, my CC is unable to render video, even at 25 FPS! I meet all the RAM requirements, the only thing different this time is a rather large environment as lightroom. Is that the problem?
jeffkirkland
jeffkirkland
Posts: 290, Visits: 1.7K
If it's only happening when rendering then I'd think it's most likely a GPU issue - either lack of RAM or drivers.
Jeff Kirkland | Director • Cinematographer • Storyteller
Hobart • Tasmania • www.one18films.com
SYSTEM: AMD Ryzen 5 5500 | 32gb RAM | RTX 3060 12gb | 1tb SSD System | 44tb HDD Storage
Posts: 15.8K, Visits: 31.4K
In cases like this, it's helpful to state your system specs.
I don't know how much VRAM your GPU has, but a reliable tool to check GPU usage is GPU-Z. It will also tell you how much system RAM is in use.
COLINMAC2
COLINMAC2
https://forum.reallusion.com/uploads/images/2f133568-cf83-47d4-9b6f-fde3.png
Posts: 5.7K, Visits: 26.5K
Your system is somewhat underpowered going by the information provided in your screen shot and there is no mention anywhere about the installed Graphic card.
Posts: 23.1K, Visits: 36.6K
COLINMAC2 (3/14/2023)
This doesn't show your graphic card but it does show you only have 8GB of system ram which is very low for software like Character Creator 4.
Please search for dxdiag.exe and run it. Then take a screenshot of the Display tab and post it here. This will show your graphic card information as this is likely the key to the problem.
COLINMAC2
COLINMAC2
Uh, something's wrong here. It won't let me insert the screenshot. I've attached the file.
Screenshot (15).png (127 views, 211.00 KB)
COLINMAC2
COLINMAC2
Would it solve my problems if I added more RAM? I've got a line on a 5TB external RAM hard drive.
You problem is that you don't have a dedicated graphics card (Nvidia, which is preferred, or AMD). All I see is Intel Graphics which is integrated with the processor and has only 4GB of RAM available, which is shared with the system RAM, which totals 8GB.
So your system (an older laptop) is greatly underpowered and it is amazing that CC4 actually runs at all.
Check the system requirements towards the end of: https://www.reallusion.com/character-creator/download.html.
Even the minimum requirements (which are hardly adequate as we have pointed out many times to RL) specify a dedicated graphics card (either Nvidia or AMD).
To run CC comfortably you should aim for at least the recommended requirements.
jeffkirkland
jeffkirkland
I think you're confusing hard drive space with system and GPU RAM. Adding a hard drive won't fix anything unless you're also running out of general storage.
Your CPU and system RAM are ok as long as you don't expect to work quickly. You might also want to stay away from larger projects. Upgrading to at least 16gb of system RAM would help you a lot in terms of speed.
The Intel graphics card will probably be the cause of your crashes, especially as you say it's lighting that giving you grief. Both CC4 and IC8 need a dedicated graphics card, preferably from NVIDIA, with a minimum of 8gb VRAM. If you intend to use iClone, I wouldn't buy a GPU with less than 12gb, preferably 16gb. That built in card with its shared memory will be running out of resources pretty quickly. I'm actually surprised you're getting to render at all.
