the i-ray function does not work well to make a video.
Posted By Shreck Charmant 3 Years Ago
Shreck Charmant
Shreck Charmant
Junior Member (130 reputation)Junior Member (130 reputation)Junior Member (130 reputation)Junior Member (130 reputation)Junior Member (130 reputation)Junior Member (130 reputation)Junior Member (130 reputation)Junior Member (130 reputation)Junior Member (130 reputation)
Posts: 7, Visits: 169
the i-ray function does not work well,when I compress a video in iray mode, my avatar loses those props, and sometimes even that hair, sometimes the avatar doesn't even move in my iRay,, I'll show you with a youtube video the example: >>>>> https://youtu.be/a2SmW0GL34I <<<<<<<<                          >>>>> https://youtu.be/OSX66tUeXtI    <<<<<<<<
>>>>> https://youtu.be/4LH5Rwi99u8 <<<<<<<<
jeffkirkland
jeffkirkland
Posts: 290, Visits: 1.7K
I'd suggest uninstalling and reinstalling the plugin and/or checking that your graphics card drivers are up to date. If none of that helps, then I'd contact RL support to see if they can help.
Jeff Kirkland | Director • Cinematographer • Storyteller
Hobart • Tasmania • www.one18films.com
SYSTEM: AMD Ryzen 5 5500 | 32gb RAM | RTX 3060 12gb | 1tb SSD System | 44tb HDD Storage
Posts: 5.3K, Visits: 16.8K
I know for sure, cloth items which have displacement maps (or tessellated) becomes static while animation is rendered with Iray: https://www.reallusion.com/FeedBackTracker/Issue/Cloth-items-becomes-static-with-Iray-render-if-tessellated-or-have-a-displacement-map
Same might be true for the characters. I have not tested that.
Shreck Charmant
Shreck Charmant
Sounds a lot like this problem, but everything I've tested here has worked before.
I will look if I can find the previous version of iray.
Shreck Charmant
Shreck Charmant
I tested what you suggest and it didn't change anything unfortunately, I installed the update for my nvidia 3070 card on my 3 computers and they all have the same problem,,
what is very strange is that even the compressions that worked no longer work.
I have 3 computers that compress in iray, I have made a lot of videos in iray and have never had so much trouble maintaining it, can I download the older version of iray?
ps. I don't understand that it's just me having this problem when I have 3 computers to test and none of them work to do something I've been doing for years.
Posts: 15.8K, Visits: 31.4K
Iray has not been updated in quite a while, so what you are using now is what you have been using before.
I think the reason that you don't see a lot of reports about problems is that many users now render in external applications such as Unreal and Blender, or just use the iClone native renderer.
Iray has a number of limitations, in that newer iClone features are not supported. It has been a disappointment frankly that Iray has not been updated to a newer version.
It may be that support in iClone 8 is somehow broken and that things still work in iClone 7.
Shreck Charmant
Shreck Charmant
I believe you are right Animagic, icon users don't use iray rendering anymore because of the time it takes I guess.
But despite everything I paid to have this iray function in all my machines.
So I just have to wait for Reallusion to update their Iray. 🤓
As I mentioned above it is a bug. And it has status "Assigned". Hopefully with iClone 8.12 (or 8.2) update release it would be fixed.
Shreck Charmant
Shreck Charmant
temporary solution by Reallusion:
This issue might not be fixed recently. The workaround is deleting the Displacement texture in Modify panel.
https://forum.reallusion.com/uploads/images/4c10184a-e557-469f-bf12-6ea8.png
