Shreck Charmant
Shreck Charmant
Visits: 169
the i-ray function does not work well,when I compress a video in iray mode, my avatar loses those props, and sometimes even that hair, sometimes the avatar doesn't even move in my iRay,, I'll show you with a youtube video the example: >>>>> https://youtu.be/a2SmW0GL34I <<<<<<<< >>>>> https://youtu.be/OSX66tUeXtI <<<<<<<< >>>>> https://youtu.be/4LH5Rwi99u8 <<<<<<<<
jeffkirkland
jeffkirkland
Last Active: 3 Weeks Ago
Visits: 1.7K
I'd suggest uninstalling and reinstalling the plugin and/or checking that your graphics card drivers are up to date. If none of that helps, then I'd contact RL support to see if they can help.
Jeff Kirkland | Director • Cinematographer • Storyteller Hobart • Tasmania • www.one18films.com SYSTEM: AMD Ryzen 5 5500 | 32gb RAM | RTX 3060 12gb | 1tb SSD System | 44tb HDD Storage
Posts: 5.3K,
Visits: 16.8K
I know for sure, cloth items which have displacement maps (or tessellated) becomes static while animation is rendered with Iray: https://www.reallusion.com/FeedBackTracker/Issue/Cloth-items-becomes-static-with-Iray-render-if-tessellated-or-have-a-displacement-mapSame might be true for the characters. I have not tested that.
Shreck Charmant
Shreck Charmant
Visits: 169
Sounds a lot like this problem, but everything I've tested here has worked before. I will look if I can find the previous version of iray.
Shreck Charmant
Shreck Charmant
Visits: 169
I tested what you suggest and it didn't change anything unfortunately, I installed the update for my nvidia 3070 card on my 3 computers and they all have the same problem,, what is very strange is that even the compressions that worked no longer work. I have 3 computers that compress in iray, I have made a lot of videos in iray and have never had so much trouble maintaining it, can I download the older version of iray? ps. I don't understand that it's just me having this problem when I have 3 computers to test and none of them work to do something I've been doing for years.
Posts: 15.8K,
Visits: 31.4K
Iray has not been updated in quite a while, so what you are using now is what you have been using before. I think the reason that you don't see a lot of reports about problems is that many users now render in external applications such as Unreal and Blender, or just use the iClone native renderer. Iray has a number of limitations, in that newer iClone features are not supported. It has been a disappointment frankly that Iray has not been updated to a newer version. It may be that support in iClone 8 is somehow broken and that things still work in iClone 7.
Shreck Charmant
Shreck Charmant
Visits: 169
I believe you are right Animagic, icon users don't use iray rendering anymore because of the time it takes I guess. But despite everything I paid to have this iray function in all my machines. So I just have to wait for Reallusion to update their Iray. 🤓
Posts: 5.3K,
Visits: 16.8K
As I mentioned above it is a bug. And it has status "Assigned". Hopefully with iClone 8.12 (or 8.2) update release it would be fixed.
Shreck Charmant
Shreck Charmant
Visits: 169
temporary solution by Reallusion:This issue might not be fixed recently. The workaround is deleting the Displacement texture in Modify panel.
