Updating an existing character in iClone from CC4??
Posted By james1981 Last Year
james1981
james1981
Posted Last Year
Junior Member (209 reputation)Junior Member (209 reputation)Junior Member (209 reputation)Junior Member (209 reputation)Junior Member (209 reputation)Junior Member (209 reputation)Junior Member (209 reputation)Junior Member (209 reputation)Junior Member (209 reputation)
Posts: 5, Visits: 40
Hey,
Does anyone know if it's possible to update a character that you've already sent from CC4 to iClone? The scenario I'm in is that I've made a character in CC4, sent that to iClone 8 and started animating. I know realize I need to change the character in various ways so would love to make the changes in CC4 then send the updates back to iClone whilst retaining the animation work I've already done.
Any help would be great, thanks.
James
Zeronimo
Zeronimo
Posted Last Year
Posts: 482, Visits: 19.3K
in iClone8 select your character and in the modify panel --> "Edit in Character creator"
https://forum.reallusion.com/uploads/images/d14fb336-8d81-46b5-8c37-03dd.jpg
in CC4 modify your character and when it's done go to the "menu" --> File --> Export --> Send to Iclone --> Send to Iclone
https://forum.reallusion.com/uploads/images/08b043c2-5764-40bb-b42d-4924.jpg
it's done
Posted Last Year
Posts: 8.2K, Visits: 62.5K
I think you mean just sending an updated character from CC4 to iClone. If your character is selected in iClone when you send the update from CC, it will update the character while maintaining the animation. No need to send the character both ways. :)
Same is true if you replace the character from the Content Manager.
james1981
james1981
Posted Last Year
Hi,
Thanks for the advice. Unfortunately this doesn't quite do the job. Whilst this process does get the character back to CC & then back to iClone, the process of bringing the character back to iClone destroys any live keyframes you've set in the timeline. The animation is still there but it's like all the animation gets baked down which is not ideal as you then lose the ability to continue working and editing the animation.
CtrlZ
CtrlZ
Posted Last Year
Posts: 328, Visits: 4.5K
Rampa (1/24/2023)
Usually there is a pop up that comes up  press no and CC character will come in without changing the motion to the CC motion (pose)
james1981
james1981
Posted Last Year
"Usually there is a pop up that comes up  press no and CC character will come in without changing the motion to the CC motion (pose)"
It does indeed show this popup, however the issue in doing this, is that it bakes any keyframes you've created down. So whilst the motion is retained you no longer have any keyframes.
CtrlZ
CtrlZ
Posted Last Year
Just resample the frames lol or  { .        .          . } set key's before and after parts you want to keep, block them out and work in the middle.
ben_385251
ben_385251
Posted 11 Months Ago
New Member (96 reputation)New Member (96 reputation)New Member (96 reputation)New Member (96 reputation)New Member (96 reputation)New Member (96 reputation)New Member (96 reputation)New Member (96 reputation)New Member (96 reputation)
Posts: 4, Visits: 209
FYI very late here  it also destroys any viseme or acculips data. Pretty outrageous there is not a simplified streamlined way to simply update a character without totally destroying hours of animation considering these are two programs supposed to be used in tandem. I've lost hours of work.
tom_453281
tom_453281
Last Active: 8 Months Ago
Posts: 1, Visits: 18
I have the same issue and was looking at having to redo days of animation work just to update a small change in my character.
However, I ended up bringing in an updated copy of the character and then manually cut & pasted the animation tracks across from the old character to the new one.
Just make sure you delete any existing animations in each track of the new character first, otherwise iClone crashes. iClone doesn't seem to like over-pasting as I guess it attempts to blend them? And of course make sure the play head is at the start of the timeline!
Not being able to dynamically update characters does seem like a bit of a flaw given this is a pretty typical studio workflow with modelling and animation work happening in parallel.
jim_612876
jim_612876
Posted 3 Months Ago
Posts: 1, Visits: 17
As far as i can see it doesnt really work.  Its amazing that i can tweak my work in iclone and it is updated in real time in Unreal Engine - but you can't update a model in CC8 and have it update in Iclone without having to import and export in which case it overwrites work.
