Problem with SPRING motion on rigged props
Posted By mschack 3 Years Ago
mschack
mschack
Junior Member (173 reputation)Junior Member (173 reputation)Junior Member (173 reputation)Junior Member (173 reputation)Junior Member (173 reputation)Junior Member (173 reputation)Junior Member (173 reputation)Junior Member (173 reputation)Junior Member (173 reputation)
Posts: 5, Visits: 122
I am having an issue with spring motion showing up on a simple rigged prop.  Here is what I do...
1) Drag and drop a PNG into the application, when I am prompted I select rigged prop.
2) I go into Composer and add a very basic bone chain of about five bones.
3) I go into the spring editor and add all bones starting at bone 2 to the default group.  (I start at bone 2 because I don't want it to start springing from the very first bone...)
[Note at this point the spring preview shows it to be behaving as expected.]
4) Go back to Stage Mode and select my tree, and open the 'Prop Key Editor'
5) I select bone 2 and rotate it slightly every 10 keyframes.
[Note with the Prop Key Editor open the spring effect is showing properly in real time as I rotate the bone at each keyframe.]
6) With my keyframes set up I close the Prop Key Editor
7) When I hit play the prop doesn't move at all
8) If I manually drag through the timeline I see that the rotation happens but no spring effect.
[Note if I open the Prop Key Editor again the spring effect comes back ]
I have found that with the same rig, if I keyframe the parent bone (bone 1) and just translate it around the spring animation then works fine.
Thanks
