mschack
mschack
Visits: 122
I am having an issue with spring motion showing up on a simple rigged prop. Here is what I do...
1) Drag and drop a PNG into the application, when I am prompted I select rigged prop. 2) I go into Composer and add a very basic bone chain of about five bones. 3) I go into the spring editor and add all bones starting at bone 2 to the default group. (I start at bone 2 because I don't want it to start springing from the very first bone...)
[Note at this point the spring preview shows it to be behaving as expected.]
4) Go back to Stage Mode and select my tree, and open the 'Prop Key Editor' 5) I select bone 2 and rotate it slightly every 10 keyframes.
[Note with the Prop Key Editor open the spring effect is showing properly in real time as I rotate the bone at each keyframe.]
6) With my keyframes set up I close the Prop Key Editor 7) When I hit play the prop doesn't move at all 8) If I manually drag through the timeline I see that the rotation happens but no spring effect.
[Note if I open the Prop Key Editor again the spring effect comes back ]
I have found that with the same rig, if I keyframe the parent bone (bone 1) and just translate it around the spring animation then works fine.
Thanks
