jamesgti14_809530
jamesgti14_809530
Visits: 338
Thanks to the devs for the fix worked a treat!
Posts: 23.1K,
Visits: 36.6K
Garry_Seven_of_one (11/26/2022) Thanks Peter, the support department has helped me fix the issue. I needed to clear some Temp directories in windows and now it works. Thanks.Great to hear Support were able to help. Thanks for letting us know. :)
Garry_Seven_of_one
Garry_Seven_of_one
Visits: 1.9K
Garry, Clearstream, Seven_of_one
 My Pinterests
Posts: 23.1K,
Visits: 36.6K
wungun (11/24/2022) All i have to say is please test your updates going forward before you release them. This poor guy had to re-install everything just to find out it did not work. This user unfortunately has issues with CC4 that appear unrelated to the update or hotfix. As can be seen from other replies, the hotfix has helped resolve the SkinGen issues for most users.
Posts: 23.1K,
Visits: 36.6K
Posts: 23.1K,
Visits: 36.6K
Garry_Seven_of_one (11/24/2022) CC4 still producing same errors afterwards.
At this point, I uninstalled iclone 8 and CC4 completely, and all the plugins. Did a registry clean and rebooted. Then I reinstalled all from scratch from Hub.
After this I tried to download the base characters and a couple of the skin packs. It crashed during install.
So now I’m left with 2 applications that I’ve invested a lot of money in, and zero content to use in either as I can’t download any without it crashing.Unfortunately, it appears that you have additional issues with CC4 that can't be fixed with the current hotfix. In this case, please contact Technical Support who will try to help you resolve the problems you are having. Please make sure to supply detailed system information (dxdiag.txt) so Support can check for any obvious problems, such as driver issues. https://www.reallusion.com/CustomerSupport/UserEx/QForm.html
Garry_Seven_of_one
Garry_Seven_of_one
Visits: 1.9K
Just to clarify about my previous post regarding re-installing everything and it still not working and having no content now, I am not furious about it or anything, these things happen. But, some sort of new version release is needed to fix the issue asap is what I was getting at., as I’m completely stuck. I’ve purchased new content in the Black Friday sale and can’t download it, or even any other pack now.
 My Pinterests
wungun
wungun
Last Active: 6 Months Ago
Visits: 3.5K
Peter (RL) (11/23/2022)
Garry_Seven_of_one (11/23/2022)Hi,
Sorry but fix has not worked for me. Still same error pointing to wrong path.
Also, I can’t install any missing content as CC4 randomly just crashes and closes whilst downloading the packs.
I uninstalled the realistic skin pack and tried to reinstall and it crashes whilst downloading it. As others have confirmed the hotfix does work, please double check that you followed the instructions for the hotfix, and you didn't get any kind of error. Once you are confident that the hotfix was installed correctly, please try resetting your Smart Content Manager Database as it may be corrupted. Please follow the instructions on the page below. So I ran the restore database file you suggested, which produced the following screen.  CC4 still producing same errors afterwards. At this point, I uninstalled iclone 8 and CC4 completely, and all the plugins. Did a registry clean and rebooted. Then I reinstalled all from scratch from Hub. After this I tried to download the base characters and a couple of the skin packs. It crashed during install. So now I’m left with 2 applications that I’ve invested a lot of money in, and zero content to use in either as I can’t download any without it crashing. Hi... This is just Irresponsible on Reallusion part I am sorry you are going through this. They should have put out videos about how the hot fix worked and sent out emails to everyone who is affected . All i have to say is please test your updates going forward before you release them. This poor guy had to re-install everything just to find out it did not work. Reallusion needs to go back to a manuel install to where you choose the correct path for content to be found. You cant do that because if you could it would not be a problem . Why did reallusion take that away and gave us the unreliable smart content manager? When using the installers back in 7 it would ask you where you want your content but you cant do that now. It dose it for you and dose a really bad job. Please fix this Reallusion. We need an update sooon!
Garry_Seven_of_one
Garry_Seven_of_one
Visits: 1.9K
I uninstalled the realistic skin pack and tried to reinstall and it crashes whilst downloading it. Hi... As others have confirmed the hotfix does work, please double check that you followed the instructions for the hotfix, and you didn't get any kind of error. Once you are confident that the hotfix was installed correctly, please try resetting your Smart Content Manager Database as it may be corrupted. Please follow the instructions on the page below. So I ran the restore database file you suggested, which produced the following screen.  CC4 still producing same errors afterwards. At this point, I uninstalled iclone 8 and CC4 completely, and all the plugins. Did a registry clean and rebooted. Then I reinstalled all from scratch from Hub. After this I tried to download the base characters and a couple of the skin packs. It crashed during install. So now I’m left with 2 applications that I’ve invested a lot of money in, and zero content to use in either as I can’t download any without it crashing.
 My Pinterests
Garry_Seven_of_one
Garry_Seven_of_one
Visits: 1.9K
I uninstalled the realistic skin pack and tried to reinstall and it crashes whilst downloading it. Hi... As others have confirmed the hotfix does work, please double check that you followed the instructions for the hotfix, and you didn't get any kind of error. Once you are confident that the hotfix was installed correctly, please try resetting your Smart Content Manager Database as it may be corrupted. Please follow the instructions on the page below. Well the instructions for the hot fix are to run 2 batch files so you can’t really get that wrong can you? When I do run them, nothing appears to be happening unless it’s so quick I didn’t see it. I assume it’s replacing just a few files. I will try the smart content reset.
 My Pinterests
