Fixing Root Motion rotation issue.
Posted By kmitchell.12catblackstudio... 3 Years Ago
Posts: 257, Visits: 1.1K
Can't see if anyone else has asked this but i'll store this here.
In the current version I guess the root motion applies rotation information in the root as well as other axis movement and in UE4/5 this causes issues with the root motion. (For me at least). Thus far I have had hid to use root to hip then remove the forward hip movement and reanimate just the Y movements by hand.
(Fix) This morning I just realized you can sampled the optimized animation for the animations in question cut the root Y movement. Transfer the root to hip which get rid of the odd XYZ rotation in the root then paste back in the Y movement to the root. Then its ready for resaving the animation back out for exporting to unreal.
This seems to be an issue on all the animations I have stored from IClone 7 before moving to IClone 8.
Wish I saw this earlier but the more you know... If this was obvious I apologize but if it helps those that do not see this I hope it helps.
Joevolve
Joevolve
Veteran Member (753 reputation)Veteran Member (753 reputation)Veteran Member (753 reputation)Veteran Member (753 reputation)Veteran Member (753 reputation)Veteran Member (753 reputation)Veteran Member (753 reputation)Veteran Member (753 reputation)Veteran Member (753 reputation)
Posts: 27, Visits: 278
*Chuckling* Such an easy fix to a very complex and hindering problem, you deserve accolades, "It WORKS!!"  I am curious though how long have you had this problem? this thing had been a serious thorn
Joevolve
Joevolve
This was my first time really getting back to the animation side of development. I believe this is an IClone 8 thing as I know this didnt happen in IC7. But man did i waste about 3 days fixing this the wrong way...
Joevolve
Joevolve
At least you figured it out, if by any chance you know the "Holy Grail" for changing inplace motion to root motion, toss a bone my way, please
Same snipps. Just go to FK select the root, set akey at 0
Move to the end of the animation then move the bone forward to the general forward direction.
Make sure in the curve editor you set this to linear (for walk / run/ sprint) so you dont get weird animation loops. The check to animation so it doesnt look like the feet are slipping. Then Save it out as Movement_RM
I have also did this for RM Jumping and sprint jumping. so you dont have to do weird root motion hacks I've seen going around.
