Wilby
Visits: 479
I have collected some MOCAPs from Unity Game Engine in the past and they are in FBX format. I'm trying to import these motions into Character Creator 4 but I cannot seem to find a good tutorial about it. Can anyone knowledgeable provide me some info on how to properly do this? I tried dragging the FBX file directly into CC4, then I selected the Humanoid option at the FBX Import window. But I was presented with a huge humanoid skeleton at it's starting animation pose. I tried scaling the whole thing but the bones just got disconnected from each other. What are the proper steps to do this successfully? I'm still new to CC4 and still trying it out to see if it will work for me. I am using the Trial version.
yepkoo
yepkoo
Posts: 1.2K,
Visits: 1.9K
In CC4 you can import characters.iC8 is required to import animations. I have successfully transferred my 1,200 animations from UE to iClone.
---------------------------------------------------------------- https://www.youtube.com/yepkoo https://dev.epicgames.com/community/profile/bxvo/Yepkoo#learning
Wilby
Visits: 479
yepkoo (10/27/2022)In CC4 you can import characters. hmm... If that's the case, what are the "Import External Motion" and "Convert External Motion" in CC4? :unsure: yepkoo (10/27/2022)iC8 is required to import animations. I have successfully transferred my 1,200 animations from UE to iClone. Do you have a tutorial that you can share on that? Maybe it's similar to how it's done for Unity. :D
yepkoo
yepkoo
Posts: 1.2K,
Visits: 1.9K
Yes you are right. I have never tried to import animations using CC4 before. More precisely, I never needed to import animations with CC4 :) I thought that part would only work for animations exported from CC. However, I was just able to successfully import an animation from UE. The Import external motion option worked. First you need to select the character on the stage, then this function becomes active. While importing the fbx file, the Unreal Engine option automatically appeared in the options. However, you still need iClone to edit these animations. CC4 only works in player mode or exports existing animations as they are. If you don't need to edit the animations, yes this program seems to do the retargeting of the animations to the CC character.
This seems like a good feature. You can create many different animations with iClone. But if you don't need animation customization, CC4 program that can quickly import characters and animations and is more affordable than IClone will be useful for most people.
Wilby
Visits: 479
yepkoo (10/27/2022) Yes you are right. I have never tried to import animations using CC4 before. More precisely, I never needed to import animations with CC4 :) I thought that part would only work for animations exported from CC. However, I was just able to successfully import an animation from UE. The Import external motion option worked. First you need to select the character on the stage, then this function becomes active. While importing the fbx file, the Unreal Engine option automatically appeared in the options. However, you still need iClone to edit these animations. CC4 only works in player mode or exports existing animations as they are. If you don't need to edit the animations, yes this program seems to do the retargeting of the animations to the CC character.
If you have an external FBX motion like for example for a humanoid biped model. How do you make it compatible with a humanoid non-standard character already inside iClone 8 or Character Creator 4? I am being asked to use a compatible 3dxProfile everytime I try to import external motions for some sample characters already available in CC4 and iClone 8. It says if I don't have one, I can create it in Character Creator 4. How do you do this?
yepkoo
yepkoo
Posts: 1.2K,
Visits: 1.9K
I don't know if I understood correctly. If you're asking if it works with any non-standard humanoid characters in the library after importing the animations you mean, it should work. At least if you look at the tree video I imported, I could easily apply any animation
Wilby
Visits: 479
yepkoo (10/28/2022) I don't know if I understood correctly. If you're asking if it works with any non-standard humanoid characters in the library after importing the animations you mean, it should work. At least if you look at the tree video I imported, I could easily apply any animation.That is a nice and useful tutorial! :) That answered half of my question. How about if you are also importing an external FBX motion from other sources like the free Everyday Motion Pack in Unity Asset Store and adding it to the character already inside CC4 (i.e. your downloaded Turbisquid Child model)? That is just an example, no need to download and use the actual motions therein. :D I've seen an old tutorial before but it uses 3DXchange Pipeline. I wanted to know how it is done without using that.
yepkoo
yepkoo
Posts: 1.2K,
Visits: 1.9K
I haven't tested it as I don't use Unity. However, the animations I imported from UE work perfectly on non-standard characters I imported with CC4 AccuRig. So I'm pretty sure your animations imported from Unity will work on all characters Since 3DXchange features are shared between CC4 and iC8, it already automates many operations. It can automatically import many animations according to the profiles it contains. I love how the RL team is making such successful developments. However, I don't like the marketing team showing the same success :D
Wilby
Visits: 479
yepkoo (10/28/2022) I haven't tested it as I don't use Unity. However, the animations I imported from UE work perfectly on non-standard characters I imported with CC4 AccuRig. So I'm pretty sure your animations imported from Unity will work on all characters Since 3DXchange features are shared between CC4 and iC8, it already automates many operations. It can automatically import many animations according to the profiles it contains. I love how the RL team is making such successful developments. However, I don't like the marketing team showing the same success :D
Since I'm having difficulty finding good retargetting tutorials in CC4 for MOCAPs coming from Unity, I decided to just try out Auto-Rig Pro + Quick Rig and Animation Layers add-ons in Blender. They just offer more support for third-party sources and I think that flexibility is what I need at my current learning phase. For now, I'm planning to just use CC3, Blender, and UE5 Pipeline because I can't also afford to upgrade to iClone 8 & CC4 at the moment anyway. Maybe late next year I will consider taking a look again at those two as they become more mature and grow with additional features. I appreciate all the assistance! Thank you! :)
