Strange onscreen noise when Importing from CC 4.02 into Unity after using URP importer
Posted By John_BE 3 Years Ago
Strange onscreen noise when Importing from CC 4.02 into Unity after...
John_BE
John_BE
Junior Member (169 reputation)Junior Member (169 reputation)Junior Member (169 reputation)Junior Member (169 reputation)Junior Member (169 reputation)Junior Member (169 reputation)Junior Member (169 reputation)Junior Member (169 reputation)Junior Member (169 reputation)
Posts: 4, Visits: 94
Hey everyone,
Just looking to see if anyone has run into this same Issue that i'm experiencing.
I was exporting some preliminary hair tests done in CC4.02 and importing them into Unity (2021.3.5f1), after the initial import as was well. However after running the FBX through the CC URP importer inside Unity, I noticed that it's applied a strange visual banding to all of the shadowed areas. The problem only occurs after the importer has run through the FBX so i'm assuming it's something that's being applied to the model by the importer.
Is there anyway to remove this effect and keep the smoother shadow?
You can see the visual noise applied below in the before and after version of the imported model.
https://forum.reallusion.com/uploads/images/5c178d76-a78b-4898-8b2d-317a.png
https://forum.reallusion.com/uploads/images/7922de03-ebf3-4dcb-9623-737e.png
Victor.Soupday
Victor.Soupday
Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)
Last Active: 12 days ago
Posts: 569, Visits: 9.0K
Found out what's causing it. I've been trying to track this down for a while.
It's caused by the SSAO depth + normals, and digging a bit deeper, the Skin Shader depth-normal pass doesn't like reusing the diffuse map sampler in 2021.x+, which causes an error and so this dithering effect in 2021.x and above. The skin shaders can use more than 16 textures and so need to re-use texture samplers, only the depth normal pass seems to be picky about which samplers it can use.
Edit: In fact it looks like all the Amplify shaders also need to be recompiled for URP 12 as it uses a different template.
