SeanMac
SeanMac
Visits: 3.4K
Hi Jeff,
Thanks for that. SeanMac
SeanMac
SeanMac
Visits: 3.4K
Hi Peter, Thanks for that.
SeanMac
Posts: 23.1K,
Visits: 36.6K
It is always easiest to just uninstall from an old computer first (while online), however if you are not able to uninstall because of hardware issues, you can manually deactivate.
Please follow the steps below to deactivate your license from a computer.
2. Check the "Activated Number" column. If your product shows 2 then you need to deactivate to be able to install again. 3. Click the "Details" link in the Activated Number column. 4. Scroll down to see the computers currently activated. 5. Click the "Deactivate Now" link to remove a computer. 6. You will now be able to install again on a different computer.
I hope this helps.
jeffkirkland
jeffkirkland
Last Active: 8 Months Ago
Visits: 1.7K
It's something I've always meant to ask about and clarify but I've done this a couple of times now, always uninstalling with the Hub first on the assumption that the Hub keeps track of the number of installs currently in play. In any event, I'm on my third major hardware update with no licensing issues.
Jeff Kirkland | Director • Cinematographer • Storyteller Hobart • Tasmania • www.one18films.com SYSTEM: AMD Ryzen 5 5500 | 32gb RAM | RTX 3060 12gb | 1tb SSD System | 44tb HDD Storage
SeanMac
SeanMac
Visits: 3.4K
Hi animagic Thnks forthat. I am just leery pf falling between two stools. I am goimg to have to uninstall on the old computer, take it apart, put the new mobo in with SSDs to replace HDDs, then download the program suites again for reinstallation and I do mpt want to be caught up on the bureaucracy. SeanMac
Posts: 15.8K,
Visits: 31.4K
Just make sure that while you uninstall from your old computer that it is connected to the internet. This will free up one install.
SeanMac
SeanMac
Visits: 3.4K
OK Thanks I'll give it a try. I will not be able to run the program on two computers because the old one will be taken apart. As for the laptop, it would be some laptop to run these advanced graphic RTX card programs. OK - I'll sign off. Thanks for the help.
yepkoo
yepkoo
Last Active: 9 Months Ago
Posts: 1.2K,
Visits: 1.9K
HUB 2 can be online on the computer. I don't think there will be an error while installing. You can install on your new computer while the program is closed on your other computer. Then you can run the program on the computer you want to work on. I have never tried it, but when you run the program on 2 computers at the same time, it probably gives a warning or it may be closing. On this matter Peter or someone who has tried it might be able to give a more precise answer. I don't think there will be any problems as long as the computers are yours. I just interpreted it the way I read it in the EULA. I found a thread about this that Peter replied to a few days ago.https://forum.reallusion.com/523730/Install-on-multiple-devices-at-once
---------------------------------------------------------------- https://www.youtube.com/yepkoo https://dev.epicgames.com/community/profile/bxvo/Yepkoo#learning
SeanMac
SeanMac
Visits: 3.4K
WE are getting crossed wires. If I download and install on my current machine, then cannibalise it whilst building another, ca I download and install on the new machine without getting caught up in license violations?
yepkoo
yepkoo
Posts: 1.2K,
Visits: 1.9K
You can install 1 copy. However, you cannot run programs at the same time. But if the versions are different, you can run them on different computers at the same time. For example, you can run ic7 on one computer and ic8 on the other.
