Visits: 3.7K
I imported a custom FBX model into CC4 & when I fetch the same model for blendshape import I get an error message(see attached images). When I import the same model into Unity the blendshapes are immediately detected & imported with no extra steps involved. What am I doing wrong? As far as I can see this should be a simple automated import process as it is in Unity. It is the same model with no topology changes at all to the body mesh upon import, I've only altered the texture maps within Gimp.
---------------------------------------------------------------------------------------------- Reallusion iClone & CC Pipeline --- Plugins: Iray HeadShot SkinGen. CrazyTalk Animator Pipeline, CrazyTalk, Maya LT, Daz, Substance Painter Indie, Substance Designer Indie, B2M Pro+ Substance Live, Sculptris, Wrap, Unity, UE4, Perception Neuron Ready:):D:P;):cool::hehe::smooooth::crazy::satisfied::Wow::pinch::exclamation::alien::discuss::kiss::arrow::(:angry::sick::exclamation::blush::Whistling::w00t::w00t::w00t: SurfaceBook 2 Windows 11 Pro 64-bit Intel(R) Core(TM) i7-8650U CPU @ 1.90GHz -2.11 GHz 512GB Solid State Hard Drive 8GB RAM Nvidia GeForce 1050GTX Dell Alienware m18X R2 18.5" Custom Convertible Tablet Windows 8.1 Pro 64-bit Intel Core I7-3840QM 2.80GHz Quad Core 8 Thread 3.2GHz Turbo 512GB Solid State Hard Drive+1TB X2 RAID Disk Drive 32GB RAM Nvidia Geforce GTX 680m 2GB X2 SLI Custom Multi-touch. Dagi capacitive touch stylus Microsoft Surface Pro 2 10.1" Tablet Windows 10 64-bit Intel Core I5-4200U 1.60GHz 2.3GHz Turbo 128GB Solid State Hard Drive 4GB RAM HD 4000 Graphics Multi-touch Wacom Digitizer screen Surface Pen+Axiotron Studio Pen Asus Vivo Tab 8" Tablet Windows 10 32-bit Intel Atom Z-3740 1.33GHz Quad Core 32GB Solid State Hard Drive 2GB RAM HD 4000 Graphics Multi-touch Wacom Digitizer Wacom stylus.
Posts: 5.3K,
Visits: 16.8K
It gives you a clue in the error. Did you rename a mesh after the import? CC adds underscores to the mesh name for spaces, but you should not rename it before blend shapes import. Mesh name is also case sensitive. Changing one letter case for the mesh name would invalidate consecutive blend shapes import.
Visits: 3.7K
4u2ges (8/27/2022) It gives you a clue in the error. Did you rename a mesh after the import? CC adds underscores to the mesh name for spaces, but you should not rename it before blend shapes import. Mesh name is also case sensitive. Changing one letter case for the mesh name would invalidate consecutive blend shapes import.
I didn't change anything on the initial imports, I have over 100+ models with blendshapes, it's the same for all that I've tried so far. I have no problem with them showing up in Unity if you look at the images. This isn't rocket science, Unity detects it & even has nobs to drag to create blendshapes, where is this in CC4? The naming is a standard viseme expression scale kit everyone uses for iPhone tracking.
Posts: 5.3K,
Visits: 16.8K
Blendshape names should not matter. For some reason CC cannot match the original import vertex count or mesh name with secondary import for blendshapes. You should probably send one of the FBX files to support for investigation. Or you may post it here for someone to try and see if it can be imported outside of your install.
Visits: 3.7K
This is a major facial blendshape issue & still no reply in 2 months. Thought the recent update would have fixed this. Please help.
