ultimativity
ultimativity
Last Active: 6 Months Ago
Visits: 737
Hello, I am trying to create an animated conveyor belt. Is it possible to animate a texture or material so that it appears to be moving as the timeline advances? Thanks
Nathan
Last Active: 4 Months Ago
Posts: 15.8K,
Visits: 31.4K
A simple way to do this is animating the UV coordinates. They will shift the texture horizontal or vertical. If the texture is seamless it will give the impression of continuous movement.
ultimativity
ultimativity
Visits: 737
Thanks for replying. Do you know of any tutorials that explain how in iClone?
Nathan
Posts: 5.3K,
Visits: 16.8K
One way to make a conveyor belt run.
Data Juggler
Data Juggler
Posts: 1.8K,
Visits: 5.6K
You're too fast 4U2Guess. I will publish mine anyway. I didn't know you could do this in IClone 8.
Amper Sand
Amper Sand
Visits: 5.2K
Me I chose a much simple way on a static treading mill: I added a simple plane (2 polys), narrowed to look like a junction, then I looped a transform (position). If you want to (re-)view the clip... :D https://www.youtube.com/watch?v=Bg-aIIOP7E8
______________________________________________________________________________ Software developer. iClone hobbyist since January 11, 2020. Best work so far: Robots among us: The Lab and The sad end of a legend In progress: Black Mamba AMD Ryzen 3950X 16C/32T 4.2 GHz, 64GB RAM, RTX2080 11GB, 2TB Samsung 970 Pro SSD, 8TB Seagate BarraCuda HDD, Win11 64-bit, iClone 8.12
ultimativity
ultimativity
Visits: 737
@4u2gesm thanks for replying. Will check this out.
Nathan
ultimativity
ultimativity
Visits: 737
@Data Juggler, thanks for replying. I will check out the tutorial.
Nathan
ultimativity
ultimativity
Visits: 737
@Amper Sand, thanks for replying. Excellent video. I have to ask; are her breasts actually bouncing in time to the song? [lmfao]
Nathan
Amper Sand
Amper Sand
Visits: 5.2K
ultimativity (8/10/2022) @Amper Sand, thanks for replying. Excellent video. I have to ask; are her breasts actually bouncing in time to the song? [lmfao]Hahaha, good question 🤗 No there was no intent on this, but technically I'm assuming if I would have had her walking in sync with the song, then for sure her springs would have resonate the same :D
Back to the original question of the topic: yesterday, after I posted, I was thinking that my solution was basically a visual trick, perfect suitable for my scene (treadmill, no texture, no closeup), but strictly speaking the correct solution is the one proposed by animagic, 4u2ges and Data Juggler above (of which I was aware when I made the clip, but I rejected it because was not very confortable to be implemented in my case)
