CC4 Not Functioning At All :-(
Posted By 3CPU 4 Years Ago
playlogic
playlogic
Senior Member (439 reputation)Senior Member (439 reputation)Senior Member (439 reputation)Senior Member (439 reputation)Senior Member (439 reputation)Senior Member (439 reputation)Senior Member (439 reputation)Senior Member (439 reputation)Senior Member (439 reputation)
Last Active: 4 Months Ago
Posts: 45, Visits: 214
3CPU (8/10/2022)
animagic (8/10/2022)
About using a 4k monitor: I'm have a Dell 4k monitor (also 3840x2160) and it works without problems. I'm using a display scale factor of 125%.
On my display the maximum it can go is 225% and Font Size of 135% without cutting off some important areas of the UI. That said, what is sorely missing in CC4 is no option to adjust scale of widgets and fonts, fonts in the panels are so tiny I have great difficulties with that. I asked tech support about CC4 .ini file to see if tweaks can be done and if not? I will proceed with a refund. I did plan to also purchase iClone 8, but at this point in time, I hardly have words to express just how depressed I feel. I sincerely hope Reallusion can provide this ini tweak with plans for a future update that will include above mentioned solution.
I agree with you that Reallusion needs to update their UI code to be more flexible; I currently use a 50" Samsung Q90B as my main monitor at a 125% with no issues. If you are still having issue...maybe looking into the DPI scaling options
via the compatibility options in the properties menu
https://forum.reallusion.com/uploads/images/1bdc8c75-509e-4181-9dc3-3efd.jpg
3CPU
3CPU
Junior Member (216 reputation)Junior Member (216 reputation)Junior Member (216 reputation)Junior Member (216 reputation)Junior Member (216 reputation)Junior Member (216 reputation)Junior Member (216 reputation)Junior Member (216 reputation)Junior Member (216 reputation)
Posts: 9, Visits: 28
* Edit Reasons:
* Launch of CC4 is resolved - I suggest running a registry cleaner and then restart the computer.
* As for other issue: I have been in contact with RL Tech Support over the past two days to resolve UI scale and believe me I tried various Windows Settings > Ease of Access > Scale % and Font %, if these settings are set too high, some of the panels such as the Export to FBX will not display all the settings including the export and cancel buttons. This experience may vary based on size and type of monitor in use. I have a 43 inch 4K display. Settings, a personal choice and consider visual impairment! And wise to avoid eye strain even for people with good eye sight. RL Tech Support suggested I post a Feedback Tracker "Solution," CC4 preferences, scale UI widgets and fonts, these options are available in other software and makes the whole UI experience so much better, so I thought that be a good suggestion for CC4.
Again, thanks to everyone for chiming in on this topic, I wish you all good health and prosperity.
Original Post:
My PC Specs:
Windows 10 Pro, I keep this bad boy well maintained for optimal perf'.
Intel 10600K -  works beautifully in Blender (Eevee) with large scenes.
32GB of DDR4
6GB VRAM (GPU)
43 inch monitor, 4K resolution.
At first I was able to launch CC4, two days later it failed. I sent at an estimated 6 messages and replies to Reallusion support regarding CC4 failure to launch, but they provided absolutely no solution and failed to respond to other issues.
I am new to CC4, perhaps fellow Reallionist may have had similar issues, and provide clues that will lead me on path to solve this.
There are other serious issues with the products I purchased from Reallusion that I cannot disclose, but have given Reallusion support enough time to respond in a satisfactorily manner.
For perspective:
I am able to run Blender scene 350ft spaceship with interior consisting of large curved image displays, computer workstations and chairs, and large graphics encased in glass, a display of a futuristic computer PCB and hardware. This scene and another city scene with trees all runs great, rendered in UHD (4K) in less than a minute. I manage this because I disable parts of the scene that are not visible, and I clean out unused materials. I am saying this because my computer runs great and has not crashed, and I have over 30 years experience with computers. But nonetheless, I am new to Reallusion but disappointed they were unable to solve the issues as explained above. I spent $600 on Reallusion products that are not functioning at all, CC4 will not launch.
