evidanse
evidanse
Visits: 435
Hi everybody I have a little trouble to link my camera to my character. (I'm ashame because it's a beginner trouble ...) When I link a camera to my character boneroot it seems to be linked to a bone (hip for exemple).... The camera moves with the bone and not the character... I join a youtube link video in which I show the process I did. https://youtu.be/hF2ABseSQ5oThx Michel Did I forget anything ? (I'm so ashame like a beginner)
thebiz.movies
thebiz.movies
Last Active: 5 hours ago
Posts: 2.1K,
Visits: 42.3K
Try linking to the rl_boneroot (top most selection in the dropdown)
evidanse
evidanse
Visits: 435
That's what I did...This is why I don't understand it doesn't work... This trouble is the same in iclone 7 and 8. I checked the parameters and I noticed nothing strange...
The only way I found to fix it , is to create a cube, attach it to the rl_boneroot and link the camera to it...
thebiz.movies
thebiz.movies
Posts: 2.1K,
Visits: 42.3K
set the video to public so we can see the issue.
evidanse
evidanse
Visits: 435
I's done ! thx
Last Active: 7 days ago
Posts: 5.3K,
Visits: 16.6K
evidanse
evidanse
Visits: 435
Oups ! I fogot to save the changes. it's fixed
Posts: 5.3K,
Visits: 16.6K
Instead of linking, attach and then disable Rotate in the Inherit.
evidanse
evidanse
Visits: 435
It works ! But in this video, Walrlord720 click in "linkage" and it works ! https://www.youtube.com/watch?v=tohyMlNAOdc&t=335s&ab_channel=WarLord720Why does it work for him and many tutorials I saw and not for me ? Anyway thx for your help !
Posts: 5.3K,
Visits: 16.6K
Tutorial is from 2017 with older version of iClone7. It does not even have Attach option for the Camera (should've been between LookAt and Path). RL has change the behavior of the Root since. Now, if you still wish to use a Link, then select Clip, from right mouse click menu select Motion Modifier and just click OK. It is going to make the Root fixed. Then it's going to work as you intended.
