iClone 8.01 and 8.02 Official Issues Thread
Posted By Peter (RL) 3 Years Ago
3
yepkoo
yepkoo
Last Active: 9 Months Ago
Posts: 1.2K, Visits: 1.9K
I don't know if this problem only happens to me.
iClone shuts down when switching projects.
I work with backup by saving my projects as different.
As soon as I open a different file that I have backed up, iClone closes, sometimes in the first time, sometimes in the second time.
There are no warnings.
It just closes.
However, if I empty the scene by creating a New Project before opening one of the backup projects, it's fine.
GARCIAGA
GARCIAGA
Junior Member (201 reputation)Junior Member (201 reputation)Junior Member (201 reputation)Junior Member (201 reputation)Junior Member (201 reputation)Junior Member (201 reputation)Junior Member (201 reputation)Junior Member (201 reputation)Junior Member (201 reputation)
Posts: 10, Visits: 207
Space Mouse Pro from 3D Connexion in CC4 work perfectly but not in Iclone 8. I have update to Iclone 8.2 and I have update the last driver to Space Mouse Pro, and it works perfectly in CC4 but not in Iclone 8 in any updated version, when I try to move the Space Mouse the screen start to move in all directions so quickly and I can´t stop it. Any solution for that??
Issue 8761
hanzel
hanzel
Senior Member (493 reputation)Senior Member (493 reputation)Senior Member (493 reputation)Senior Member (493 reputation)Senior Member (493 reputation)Senior Member (493 reputation)Senior Member (493 reputation)Senior Member (493 reputation)Senior Member (493 reputation)
Posts: 23, Visits: 92
Same here,
* I can start Faceware
* In Iclone 8.02 I can select the character
* Open Motion Live plugin in Iclone 8.02
* It shows Faceware Realtime in the Gear list and I can select it
* In the character list it shows my character, but I can't select face
In the right column it shows
Character : The character name
Data: None
I can switch the fields between mask - strength and smooth and select or deselect there
Auto-Blink is automatically set to None and I can't change it anymore
TonyDPrime
TonyDPrime
Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)
Posts: 3.4K, Visits: 12.4K
Thought I'd share this, I was exporting out an Alembic to see how it would work in a UE5 environment, and I just so happened to look at the Alembic back in iClone.
(1) I exported a clothing animation from iC8 as Alembic
(2) when imported back into iC8, Alembic did not then exactly match the character's shape, per-frame on the same animation.  The character mesh now had poke through with the Alembic
So either the export out is an issue, or the import of the Alembic back in is an issue in iC8:
EDIT
Submitted through FB Tracker
https://www.reallusion.com/FeedBackTracker/Issue/Alembic-Issue
fernando.er.moraes
fernando.er.moraes
Posts: 1, Visits: 9
Same problem here. I cant use the motion live in iclone 8
Amper Sand
Amper Sand
Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)
Posts: 731, Visits: 5.2K
Peter (RL) (7/22/2022)
Thanks for the feedback. This should hopefully be corrected in the 8.1 update.
Btw, Peter, just curious, maybe you know: what's the reason of making those reach dummies so "high-poly", 1K each? :w00t:
______________________________________________________________________________
Software developer. iClone hobbyist since January 11, 2020. Best work so far: Robots among us: The Lab and The sad end of a legend
In progress: Black Mamba
AMD Ryzen 3950X 16C/32T 4.2 GHz, 64GB RAM, RTX2080 11GB, 2TB Samsung 970 Pro SSD, 8TB Seagate BarraCuda HDD, Win11 64-bit, iClone 8.12
Posts: 23.1K, Visits: 36.6K
BiggsTrek (6/28/2022)
This is a minor issue, and may have already been mentioned, but I don't see it in this thread (maybe elsewhere?)  Anyway, it's this:
Reach Target has an option to "Create Dummy" (which I love, btw) but the issue is that the pretty box it creates is NOT a dummy.  I have to manually "Set as dummy" in the Modify panel myself, otherwise it renders out if still visible.
I know, it's easy as heck to fix from a User's point of view, but I thought I'd mention it anyway.
(Back to it!)
Amper Sand
Amper Sand
In 8.02, Navigation bar's "Start" and "End" buttons no longer scroll the timeline to the cursor/scrubber, you have to manually drag the scrollbar to find the cursor/scrubber.
The same issue (but not IC8.02 specific) for Timeline's "Next key" and "Previous Key" buttons.
Dear iClone Users,
We have now released a new update to iClone (8.02) which fixes a lot of issues previously reported. However, we still need your help to track down remaining bugs or issues.
Important: If you do find any bugs, issues or glitches in iClone 8.02, please can you report them first in the Feedback Tracker. Then feel free to discuss the issues in this thread but do try to include a link back to the original Feedback Tracker report or your tracker number.
As always it will help us greatly if we can keep all technical issues in the one place (this thread). This will help the development team keep track of any problems.
Please do try to provide your full system specifications and a detailed description of the problem when reporting issues and include screenshots and/or a workflow video whenever possible. If you can provide specific steps so we can try and reproduce the problem that will be even better.
Many thanks and have fun with iClone 8.
westworld_953480
westworld_953480
Junior Member (114 reputation)Junior Member (114 reputation)Junior Member (114 reputation)Junior Member (114 reputation)Junior Member (114 reputation)Junior Member (114 reputation)Junior Member (114 reputation)Junior Member (114 reputation)Junior Member (114 reputation)
Posts: 3, Visits: 33
Please understand that the sentence is akward using a translator.
The lastest version of IClone 8.01, Optiktrack 3.0.0 is in use.
I tried to work with Motion Live., but skeleton is not following me properly.
I've seen all the manuals, but they're all old versions, so it's not helpful.
Please give me a quick answer.
3
