Sculpt Morph doesn't work.
Posted By dexterhu 3 Years Ago
dexterhu
dexterhu
Junior Member (247 reputation)Junior Member (247 reputation)Junior Member (247 reputation)Junior Member (247 reputation)Junior Member (247 reputation)Junior Member (247 reputation)Junior Member (247 reputation)Junior Member (247 reputation)Junior Member (247 reputation)
Posts: 4, Visits: 11
Hi,
Please help. I found I have no headshot folder with my cc3/cc4 base avatar, and after I active Sculpt Morph and after I click a section on the face and drag nothing happen.
I'm using Character Creator 4 v4.0 with Headshot Plug-in for Character Creator 4 v1.0 which is the latest version I could get from hub.
Threaded View
Threaded View
Forum Post Sculpt Morph doesn't work. By dexterhu ( 3 Years Ago )
Forum Post Hello, Could anyone help me? Thanks! By dexterhu ( 3 Years Ago )
Forum Post Try this: Sync. Select the Pack tab. Chooser the "All" category.... By Rampa ( 3 Years Ago )
Forum Post Thank you for your replying. I did what exactly like you said. As... By dexterhu ( 3 Years Ago )
Forum Post Hi . This solution didn't work. By cgpaarseh ( 3 Years Ago )
Forum Post I have the same problem here. i can't Morph with Headshot's sculpt... By cgpaarseh ( 3 Years Ago )
Forum Post My problem exactly like @cgpaarseh described, and like we said Rampa's... By dexterhu ( 3 Years Ago )
Forum Post Have you registered the headshot key and installed plugin in hub?... By santeri.oksanen ( 3 Years Ago )
Forum Post Find the update link for your plugins and resource packs here:... By Rampa ( 3 Years Ago )
Forum Post I believe I have found the answer to your question Download the... By zeugmatrix ( 3 Years Ago )
Forum Post Sorry for the bump but I am facing the exact same issue. Regardless of... By Goatcheese ( 2 Years Ago )
Forum Post I fixed this issue by rescanning the library. Maybe it can work for... By yepkoo ( 2 Years Ago )
Forum Post Thanks for the suggestion, yepkoo. :) I just tried that now and still... By Goatcheese ( 2 Years Ago )
Forum Post Peter had shared a patch. Maybe it will work for this issue.... By yepkoo ( 2 Years Ago )
Forum Post Will give it a go! Thank you so much for the assistance. I'm in... By Goatcheese ( 2 Years Ago )
Forum Post You'd better take another look. maybe you have overlooked something.... By rosuckmedia ( 2 Years Ago )
Forum Post [quote][b]rosuckmedia (1/19/2023)[/b][hr] You'd better take another... By Goatcheese ( 2 Years Ago )
Forum Post sorry I had overlooked I have added a photo in my post Without... By rosuckmedia ( 2 Years Ago )
Forum Post I did not see it in your video. If you click that arrow for the menu,... By 4u2ges ( 2 Years Ago )
Forum Post @4u2ges Hi! :) Yes, the "All" was selected. Still, nothing. I've... By Goatcheese ( 2 Years Ago )
Forum Post OK, just want to make sure. You mentioned the plug-in, but did you... By 4u2ges ( 2 Years Ago )
Forum Post [quote][b]4u2ges (1/20/2023)[/b][hr]OK, just want to make sure. You... By Goatcheese ( 2 Years Ago )
