kitkho (8/10/2024)
Hi Rampa, thanks for the tips. I have tried your suggested work around but the water still appeared. Kindly refer to the video attached:
These issues only affected the modifiers in "purple" color in the Modify panel on the right. E.g. Head Scale, Head Upper Width, Head Upper Width L etc.
FYI, this is not Trial version. Any further suggestion on how to solve the watermark in headshot modifiers which are in purple color?This needs a different solution than this old post. Sorry for the confusion, this a license refresh issue you have. The morph sliders showing trial are from the "Headshot Morph 1000+" pack. If you have a licensed version that came with Headshot (either version) Please try the following steps:
Make sure you have an active internet connection.
Select "Activate Purchased Items" from the Help menu. Check if solved.
Select "Activate Entire Library" from the Help menu. Check if solved.
Uninstall the pack by right-clicking the thumbnail in the Smart Content Manager and selecting "Uninstall Content". When the thumbnail turns gray, double-click it to reinstall the pack.
