IF HEADSHOT IN CC4 GIVES WATERMARK, TRY THIS
Posted By Rampa 4 Years Ago
kitkho
kitkho
New Member (90 reputation)New Member (90 reputation)New Member (90 reputation)New Member (90 reputation)New Member (90 reputation)New Member (90 reputation)New Member (90 reputation)New Member (90 reputation)New Member (90 reputation)
Posts: 5, Visits: 168
Hi Rampa!  Thank you for your prompt reply.
1. Activate Purchased Items from Help Menu - DONE;
2. Activate Entire Library - DONE;
https://forum.reallusion.com/uploads/images/91a28e8c-ce01-47e5-ac0e-5e02.png
The watermark issue gone after following the steps as you have mentioned above.
Thanks again for your help.
Posts: 8.2K, Visits: 62.6K
kitkho (8/10/2024)
Hi Rampa, thanks for the tips.  I have tried your suggested work around but the water still appeared.  Kindly refer to the video attached:
These issues only affected the modifiers in "purple" color in the Modify panel on the right.  E.g. Head Scale, Head Upper Width, Head Upper Width L etc.
FYI, this is not Trial version.  Any further suggestion on how to solve the watermark in headshot modifiers which are in purple color?
This needs a different solution than this old post. Sorry for the confusion, this a license refresh issue you have. The morph sliders showing trial are from the "Headshot Morph 1000+" pack. If you have a licensed version that came with Headshot (either version) Please try the following steps:
Make sure you have an active internet connection.
Select "Activate Purchased Items" from the Help menu. Check if solved.
Select "Activate Entire Library" from the Help menu. Check if solved.
Uninstall the pack by right-clicking the thumbnail in the Smart Content Manager and selecting "Uninstall Content". When the thumbnail turns gray, double-click it to reinstall the pack.
kitkho
kitkho
gonzeac
gonzeac
Junior Member (145 reputation)Junior Member (145 reputation)Junior Member (145 reputation)Junior Member (145 reputation)Junior Member (145 reputation)Junior Member (145 reputation)Junior Member (145 reputation)Junior Member (145 reputation)Junior Member (145 reputation)
Posts: 14, Visits: 53
Thanks Rampa, this is very helpfull
Last Active: 5 Months Ago
Posts: 15.8K, Visits: 31.4K
I have reported it as a bug in FT, because that's what it is.
https://www.reallusion.com/FeedBackTracker/Issue/Creating-a-Headshot-character-results-in-watermark.
BiggsTrek
BiggsTrek
Posts: 950, Visits: 12.3K
Thanks Rampa, I was having that trouble.  Raised a Ticket on it, too.  Hopefully they'll fix it properly, but this works for me now (as a workaround)!
https://marketplace.reallusion.com/iclone/author/biggstrek
Hi everyone,
If you are getting a watermark using Headshot in CC4, there is a quick and easy workaround.
Load a character from your Content Manager.
In the Headshot panel where is asks for type, select "Current". THis will generate a head on your currently loaded character, and avoid a watermark.
https://forum.reallusion.com/uploads/images/ecd7bc9b-9a8f-410e-8328-2330.jpg
