Character Creator 4 UI fills entire screen
Posted By Mikay² 4 Years Ago
Mikay²
Mikay²
Posts: 76, Visits: 1.3K
Hi, I just downloaded CC4 and, unlike CC3, the UI elements are huge and fill up my entire 2560x1600 display.
Is there a way to make the elements smaller?
https://forum.reallusion.com/uploads/images/7943cd1d-84cb-4832-b060-c6ca.png
PRP1986
PRP1986
Senior Member (340 reputation)Senior Member (340 reputation)Senior Member (340 reputation)Senior Member (340 reputation)Senior Member (340 reputation)Senior Member (340 reputation)Senior Member (340 reputation)Senior Member (340 reputation)Senior Member (340 reputation)
Posts: 9, Visits: 1.1K
Hi, if you go into your display settings (right click on your desktop background) you can reduce the display size under 'Scale and Layout'. I reduced mine to 175% which fixed the issue.
animatedbeing
animatedbeing
Veteran Member (881 reputation)Veteran Member (881 reputation)Veteran Member (881 reputation)Veteran Member (881 reputation)Veteran Member (881 reputation)Veteran Member (881 reputation)Veteran Member (881 reputation)Veteran Member (881 reputation)Veteran Member (881 reputation)
Last Active: 3 Weeks Ago
Posts: 114, Visits: 1.8K
The Content window seems to be the problem for iClone and CC4. The Scene window is a problem for iClone but not CC4. You can't resize it. I had to close the windows after loading content. I also moved the Modify window to the left side to get more space.
Keeping the windows display settings scale at a small setting 100% or 125% is better, as is having a high monitor resolution.
CyberFybrous
CyberFybrous
Veteran Member (550 reputation)Veteran Member (550 reputation)Veteran Member (550 reputation)Veteran Member (550 reputation)Veteran Member (550 reputation)Veteran Member (550 reputation)Veteran Member (550 reputation)Veteran Member (550 reputation)Veteran Member (550 reputation)
Posts: 40, Visits: 265
'and not being able to get to the 'export button' in certain scenarios is inexcusable.
That, plus not being able to resize dialogue boxes.
