CyberFybrous
CyberFybrous
Visits: 265
'and not being able to get to the 'export button' in certain scenarios is inexcusable. That, plus not being able to resize dialogue boxes.
animatedbeing
animatedbeing
Visits: 1.8K
The Content window seems to be the problem for iClone and CC4. The Scene window is a problem for iClone but not CC4. You can't resize it. I had to close the windows after loading content. I also moved the Modify window to the left side to get more space. Keeping the windows display settings scale at a small setting 100% or 125% is better, as is having a high monitor resolution.
PRP1986
PRP1986
Visits: 1.1K
Hi, if you go into your display settings (right click on your desktop background) you can reduce the display size under 'Scale and Layout'. I reduced mine to 175% which fixed the issue.
Mikay²
Mikay²
Visits: 1.3K
Hi, I just downloaded CC4 and, unlike CC3, the UI elements are huge and fill up my entire 2560x1600 display. Is there a way to make the elements smaller?
