iClone 8 initial setup problems
Posted By yepkoo 3 Years Ago
yepkoo
yepkoo
Last Active: 9 Months Ago
Posts: 1.2K, Visits: 1.9K
There seems to be some issues.
I deleted all content and programs.
I'm trying to do a zero install.
1- I'm getting an error while downloading some content. "Failed to install content during decryption."
The interesting thing is that it doesn't matter if I use CC4 or iC8 to download the content, the same content constantly has problems.
2- iClone 8 and the database used by the program have been using my CPU at 100% for about half an hour and slowed my computer down a lot.
3- Although I close the iClone8 Program, it continues to run in the background even though the program itself is closed, if I do "End task" from the task manager, it closes.
I still haven't been able to fully download all the content.
yepkoo
yepkoo
Headhsot Morp 1000+ is definitely not installing.
When the download reaches around 20% it just waits and sometimes the program crashes.
I downloaded it as .rlcontent from the download page and when I run it it says the CC program is not installed.
sungod
sungod
Last Active: 5 Months Ago
Posts: 249, Visits: 3.7K
yepkoo (5/12/2022)
I will check soon and let you know,
Meanwhile you might want to remove All RL things using Revo uninstaller maybe?
yepkoo
yepkoo
Thank you sungod.
It was installed after waiting for about 20 minutes.
It does not load as .rlcontent.
The only problem is that the following 6 content does not load and gives an error.
Others are not important but animation pack is important and I need to install it.
If you have this animation package, you can try to install it on iC8. (Endearment Vol.2 Lovers)
https://forum.reallusion.com/uploads/images/686ac9ea-927a-4187-9c90-f344.jpg
sungod
sungod
I think i dont have Endearment pack. I will have to check.
yepkoo
yepkoo
I reinstalled iClone7 and tried to install the animation pack but it doesn't load and gives the same error.
I can't install this animation pack at all.
According to my guess, it is related to the database used by the programs, I realized that I cannot use the animation package without formatting my computer. I've seen other users having this issue on the feedback page, and RL doesn't seem to be able to find the cause of this issue.
The reason I thought it was database sourced, when I installed iClone7, all the content was showing as if it was loaded. However, I had already deleted all the folders. Although I uninstalled the programs, the database was not deleted or reset. This caused problems as I did a zero install.
I couldn't find an option to reset or rebuild the database in the tools.
sungod
sungod
yepkoo (5/12/2022)
Try Revo Uninstaller.
Just FYI i use its Pro Version for every installations , its better than re formatting
https://www.revouninstaller.com/
All the best. I am still downloading stuff etc at slow pace due to others tasks
yepkoo
yepkoo
I might try this method first but I doubt it will delete the database completely.
videodv
videodv
Posts: 342, Visits: 12.0K
Just tried on my system and it installed ok.
Chris.
sungod
sungod
After program installation it scans for left over files and registries etc and removes very thoroughly.
I usually uninstall everything with this
