yepkoo
yepkoo
Posts: 1.2K,
Visits: 1.9K
Hello Edward (RL) , I sent the ticket, thanks :)
---------------------------------------------------------------- https://www.youtube.com/yepkoo https://dev.epicgames.com/community/profile/bxvo/Yepkoo#learning
Edward (RL)
Edward (RL)
Last Active: 5 days ago
Visits: 4.9K
yepkoo (5/12/2022) Is there any harm in installing this content on regular HDD instead of SSD?
Hello yepkoo,
The new Content Manager supports HDD, SDD, and even the USB drive. The difference is the loading and installation time. For your installation issue, we may need to collect some system information from you. Please submit a support ticket so that we can keep tracking your issue. :D
Edward
yepkoo
yepkoo
Posts: 1.2K,
Visits: 1.9K
Is there any harm in installing this content on regular HDD instead of SSD? A short-term slowness will not be a problem when adding content only. I guess there is no direct link to the content during the work.
sungod
sungod
Visits: 3.7K
After program installation it scans for left over files and registries etc and removes very thoroughly. I usually uninstall everything with this
videodv
videodv
Visits: 12.0K
Just tried on my system and it installed ok.
Chris.
yepkoo
yepkoo
Posts: 1.2K,
Visits: 1.9K
I might try this method first but I doubt it will delete the database completely.
sungod
sungod
Visits: 3.7K
yepkoo (5/12/2022) I reinstalled iClone7 and tried to install the animation pack but it doesn't load and gives the same error. I can't install this animation pack at all. According to my guess, it is related to the database used by the programs, I realized that I cannot use the animation package without formatting my computer. I've seen other users having this issue on the feedback page, and RL doesn't seem to be able to find the cause of this issue.Try Revo Uninstaller. Just FYI i use its Pro Version for every installations , its better than re formatting https://www.revouninstaller.com/All the best. I am still downloading stuff etc at slow pace due to others tasks
yepkoo
yepkoo
Posts: 1.2K,
Visits: 1.9K
I reinstalled iClone7 and tried to install the animation pack but it doesn't load and gives the same error. I can't install this animation pack at all. According to my guess, it is related to the database used by the programs, I realized that I cannot use the animation package without formatting my computer. I've seen other users having this issue on the feedback page, and RL doesn't seem to be able to find the cause of this issue. The reason I thought it was database sourced, when I installed iClone7, all the content was showing as if it was loaded. However, I had already deleted all the folders. Although I uninstalled the programs, the database was not deleted or reset. This caused problems as I did a zero install. I couldn't find an option to reset or rebuild the database in the tools.
sungod
sungod
Visits: 3.7K
I think i dont have Endearment pack. I will have to check.
yepkoo
yepkoo
Posts: 1.2K,
Visits: 1.9K
Thank you sungod. It was installed after waiting for about 20 minutes. It does not load as .rlcontent.The only problem is that the following 6 content does not load and gives an error. Others are not important but animation pack is important and I need to install it. If you have this animation package, you can try to install it on iC8. (Endearment Vol.2 Lovers)
