Hey Doriana,
My guess is that the problem lies in the Ray trace shadows and that it is not an Unreal version thing.
Try the following:
1. Pick your main light source in your World outliner (Top Right Window). Then go down to the details window (bottom right panel). Now search for Ray trace shadows. Untick the box (ie disable it) and you should see an immediate difference. You may need to do this with any other significant lights sources.
2. Then, you need to edit the characters materials. Double click on your characters material image/tab in the details panel. This will open the materials window. Now you need to scroll down and find the materials for the eyebrows (and untick the cast shadows box). You may have to do this for all the hair material elements (if there is more than one). The same will have to be done with the eyelashes and hair.
Hopefully these two things will eliminate the dark shadows.
PS: This is one of the reasons I upgraded to UE5, where I use Lumen lighting, rather than Ray Tracing.
Allistair
2 Years Ago by
Wholesome 3D
