bloodofnp
bloodofnp
Visits: 97
As I'm very fresh to 3dxchange and running into a lot of problems, I search here and find that the general consensus is that Reallusion ripped everyone off with 3dxchange, and that its getting incorporated into cc4 and icl8. I'm not finding any current topics with the issues I'm dealing with (or any like the forum kinda went blank as far as 3dxc issues), although it seems ppl have dealt with very similar issues in the past. Has everyone given up and if so is there a fix or go around? Any help would be greatly appreciated.And look how small the windows/txt are at the right in comp to the notification (which is normal size for all other apps etc
michaelrbarton
michaelrbarton
Visits: 11.2K
 I think 3DXChange is a 32 bit program. There is a 4GB patch to enable more memory for 3DXChange. Here is the link to download the free 4GB patch. 4GB Patch – NTCore I use it and it works. Before loading 3DXChange, or any 32 bit program, you have to open the 4GB patch first, then locate the 3   DXChange.exe file and click or double click it, and it should say loaded successfully. Then open up 3DXChange, and it should have the extra GB to work better.
Posts: 15.8K,
Visits: 31.4K
RL didn't rip anybody off. You can import directly into iClone and work around the 32-bit limitation.
AutoDidact
AutoDidact
Last Active: 4 Months Ago
Posts: 2.1K,
Visits: 13.6K
Still vital to my hybrid pipeline for retargeting Mixamo to Daz Genesis.
General Picture Animation
Visits: 6.6K
animagic (3/18/2022) RL didn't rip anybody off. You can import directly into iClone and work around the 32-bit limitation.What? Can you unpack that remark?
Animating now to life itself --Walt Whitman
michaelrbarton
michaelrbarton
Visits: 11.2K
I think you have to own 3DXChange to import FBX and OBJ using IC7.
Posts: 15.8K,
Visits: 31.4K
michaelrbarton (3/18/2022) I think you have to own 3DXChange to import FBX and OBJ using IC7.You are correct. I assumed the OP had 3DXchange. But that enables the direct import function in iClone.
Jeffster The Mighty
Jeffster The Mighty
Visits: 1.2K
What else is running? I only get memory can't be referenced errors when I'm running iClone for a while, rendering in Iray and tweaking. It doesn't happen when I'm just rendering hundreds of frames. Only when I'm rendering and working and rendering and working. Or working while the standalone renderer is plodding along in the background. The video memory starts getting lower and lower, and then I get a similar error. Is the program you exported from still running? Is there a game on pause in the background?
planetstardragon
planetstardragon
Posts: 11.5K,
Visits: 46.0K
despite it's 32 bit limitation - 3DX is actually one of my fav tools to use, it's fast to work with, it's useful beyond just iclone and imo 3DX6 and 3DX7 will both be collectors items, for reasons I won't go into detail about. It's one of those things that RL probably wants me to keep to myself lol :w00t:
Posts: 5.7K,
There's no way that I'm giving up on 3DXchange. It's the only way to get simple SketchUp models in to iClone, and when it was announced that it would be integrated in iClone and CC for the next releases I was told in a post on the Forum that SketchUp support would not be included. For simple lo-poly background stuff I still use SketchUp 8 to make them - 8 was the last Google version that did not have any of the restrictions forced on users by Trimble, and as long as it does what I require then it's staying on my system.
