Rotate material at angle other than 90 degrees
Posted By plan111 3 Years Ago
plan111
plan111
Last Active: 8 Months Ago
Posts: 80, Visits: 226
Hi.
Is there a way to rotate a material by an amount other than 90 degrees? In the Material tab of the modify panel, on top, right under the “Strength” slider there is a “UV Settings” section with a couple of buttons to rotate the material but they only rotate by 90 degrees.
All the way down the panel, there is another UV Settings section with a rotate text box to enter a value, but whatever value I enter, it only gives me weird results, and I can’t even undo them, I have to remove the material and start over again.
And by the way, what is the difference between those two UV Settings sections? I’ve attached a screenshot.
Thanks.
https://forum.reallusion.com/uploads/images/cc5e3219-d9fb-4fc3-baae-d3de.png
