Iclone to Cinema4D C4D - Joints oriented Y-up?
Posted By OokamiOokami 3 Years Ago
OokamiOokami
OokamiOokami
Veteran Member (738 reputation)Veteran Member (738 reputation)Veteran Member (738 reputation)Veteran Member (738 reputation)Veteran Member (738 reputation)Veteran Member (738 reputation)Veteran Member (738 reputation)Veteran Member (738 reputation)Veteran Member (738 reputation)
Posts: 39, Visits: 248
Hi, is there a way to export an FBX our of Iclone with the rig oriented as Y-up?
Exporting using either C4D preset creates an FBX rig that is oriented Z-up. The root bone then has an added -90 rotation to make the character appear to be oriented Y-up. This is fine for some uses, but is problematic if you want to make a ragdoll or use physics. Any tips on how I can export a proper Y-up rig?
Thanks much
oonabe
oonabe
Veteran Member (901 reputation)Veteran Member (901 reputation)Veteran Member (901 reputation)Veteran Member (901 reputation)Veteran Member (901 reputation)Veteran Member (901 reputation)Veteran Member (901 reputation)Veteran Member (901 reputation)Veteran Member (901 reputation)
Posts: 79, Visits: 1.4K
this would interest me as well, all I could find so far implies the use of 3dxchange but I would like to find out if there is a way to export directly from iClone with a Y-up setting
if you want to know how to do this with 3dxchange there is this information on the documentation, unfortunately I haven't been able to find a way to do this directly inside iClone
https://manual.reallusion.com/3DXchange_6/ENU/Pipeline/05_Export/Y_Up_or_Z_Up.htm
