Problem with Face Key and Face Puppet with G5 heads
Posted By Ian_L 3 Years Ago
Ian_L
Ian_L
Senior Member (256 reputation)Senior Member (256 reputation)Senior Member (256 reputation)Senior Member (256 reputation)Senior Member (256 reputation)Senior Member (256 reputation)Senior Member (256 reputation)Senior Member (256 reputation)Senior Member (256 reputation)
Posts: 4, Visits: 79
I've started working on a project that requires G5 characters, due to the game engine used only supporting skeletal facial animation, and I've noticed that Face Puppet and Face Key no longer seem to be working on G5 standard characters if I swap the heads for other G5 heads I have.  I get the usual warning regarding the missing extra expression items but nothing works at all where-as I'm sure they used to, although it's been a while since I worked with G5 characters.  I'm on the latest 7.93 version of iClone7.
My first reaction was to test them in iClone6 and they are all working as expected there.  So out of interest I exported a character with a replaced G5 head to 3DXchange and checked the expression list, the standard 36 expressions appeared to be set so I set the remaining additional 24 expressions that are part of the newer expression set and saved it back to iClone.  Everything now worked, so I saved the head as a custom head.  However, if you now use the custom head on a G5 character that fails again in the exact same way, nothing works!  This means effectively I'd have to modify the heads expression list everytime I used them which is annoying to say the least.  Only the Standard G5 Chuck character head appears to work as expected, which is the one getting swapped out of course.  Is this a bug that's crept in since I last worked with G5 characters?
I note I can save the whole character once I've updated the head as a custom character or export and reimport in as an iAvatar and they continue to work.
Last Active: 6 days ago
Posts: 15.8K, Visits: 31.4K
I just tried with a custom G5 character and the default profile (without ExPlus obviously) works as expected.
ExPlus options don't even show up for the character, so I don't get any warnings.
I can use the Face Puppet and set Face Keys. So I don't seem to understand what is not working for you.
Ian_L
Ian_L
Thanks for your response.
It would appear from further investigation that the facial animation features for any standalone G5 character heads when placed on a G5 character only work once the entire character has been saved and reimported, this includes exporting to 3DXchange7 and simply immediately re-applying to iClone or saving as an iAvatar file or as a project direct from iClone and reopening them.  So clearly the import process is updating the system to work with the new one, however simply saving the heads as a custom head once working does not preserve this.  As soon as you replace the head again facial animation stops working with regard to the facial puppet and face key tools, they all appear active but there is no response at all in the face to changes made in the tools until the character is exported and subsequently imported again.
Whether this is a bug or expected behaviour I don't know, but now I'm aware of this I can work with it.
