Steffie X. (1/9/2022)
Hi, I'm trying out Cartoon Animator 4 today, but can't get it to work.
Problem 1: Only G2 characters can show in the project. If I select others, they don't show or load failure. Are only G2 characters allowed to be used for trial versions?
Problem 2: Live Face (iPhone)
My iPhone was connected successfully (see the green light on the control panel). But I can't feed my face movement to the character via iPhone. After right click the triangle warning sign in character list, it didn't let me choose the feed from iPhone (see screenshot below). Is this because I am using a trial version again?
I'm a newbie in cartoon animation. Appreciate if someone could help.
Thanks in advance!
Steffie
Hi,
You can try to use the "Focus object" to reset the camera position.
Hotkey is "F", but you need to select the object from Scene Manager.
Regarding problem 2, I cannot reproduce your issue but I guess you could click the wrong position.
You must click the triangle button.
You can pass your issue to "
Technical support" if you still have a problem, which will help you to resolve your issue.
; height: 22px; width: 22px; top: 10px; left: 10px;">
