iClone4 PRO - Icon "Snap to Terrain or Following terrain or Off"
Posted By giannigodi 14 Years Ago
giannigodi
giannigodi
Posted 14 Years Ago
Veteran Member (874 reputation)Veteran Member (874 reputation)Veteran Member (874 reputation)Veteran Member (874 reputation)Veteran Member (874 reputation)Veteran Member (874 reputation)Veteran Member (874 reputation)Veteran Member (874 reputation)Veteran Member (874 reputation)
Last Active: 10 days ago
Posts: 25, Visits: 541
Hi
Need some help.
My iClone 4 PRO works OK except the following: on the CONTROL BAR no way to activate the "Snap to Terrain or Following terrain or Off" icon. I followed tutorials, manual instruction etc. without any result. So I am not able to use related functions.
What's wrong?
Tks
Posted 14 Years Ago
Posts: 22.7K, Visits: 35.7K
Hi,
When you say you can't activate it do you mean the options are grayed out?
The selection is made via dropdown and once selected the option becomes active.
So for example if you load in a terrain from Set -Terrain and then an avatar like Dylan and you choose Follow Terrain, Dylan will follow the contours of the hills etc as you move him about.
If you try this does it not work for you?
giannigodi
giannigodi
Posted 14 Years Ago
Tks Peter for the replay.
The terrain option is permantly greyed out. The little triangle is not grey (i.e. it is white) but it is not active.
After your reply I went to the PREFERENCE PANEL and I turned off the GIZMO button and soon after the terrain options started working, instead the Scale Object button is permanently grey. I can change scale/size only in the Modify page.
PC used:
HP dv9000 Pavillon equipped with AMD Turion 64x2 Moile technology TL.52
RAM: 2 Gbytes
Video Card: NVIDIA GeForce Go 7600 Driver: nv4_mini.sys
Tks again for your help
Lentamente
Lentamente
Posted 10 Years Ago
Veteran Member (613 reputation)Veteran Member (613 reputation)Veteran Member (613 reputation)Veteran Member (613 reputation)Veteran Member (613 reputation)Veteran Member (613 reputation)Veteran Member (613 reputation)Veteran Member (613 reputation)Veteran Member (613 reputation)
Posts: 12, Visits: 465
If the answer is still usefull to someone: you have to use Ctrl-Q to alternate from the snap to terrain or following terrain tool to the gizmo tool and from the gizmo tool to the snap to terrain or following terrain tool. Since it took me a long time to find that out, I thought someone would appreciate to have an answer to that question.
10 Years Ago by Lentamente
colour
colour
Posted 10 Years Ago
Distinguished Member (11.6K reputation)Distinguished Member (11.6K reputation)Distinguished Member (11.6K reputation)Distinguished Member (11.6K reputation)Distinguished Member (11.6K reputation)Distinguished Member (11.6K reputation)Distinguished Member (11.6K reputation)Distinguished Member (11.6K reputation)Distinguished Member (11.6K reputation)
Posts: 5.2K, Visits: 8.1K
"Lentamente (7/13/2014)
If the answer is still usefull to someone: you have to use Ctrl-Q to alternate from the snap to terrain or following terrain tool to the gizmo tool and from the gizmo tool to the snap to terrain or following terrain tool. Since it took me a long time to find that out, I thought someone would appreciate to have an answer to that question."
I didn't know that (Although I very seldom use it). Thanks. Very Useful Post Smile
BTW - Characters automatically Follow Terrain.
1) Select a Terrain
2) Right-click on Character
3) Select; "Walk Forward" in Menu Pop-up
4) select a point on the Terrain
5) Play-back. Character automatically Walks Forward, following the Terrain to the point which you selected.
