Wonder Nexus 3D
Wonder Nexus 3D
Visits: 110
Hello, so when i create any character in cc3 v3.44, i then transfer it to blender 3.0 as an FBX model and the model looks ok at first, but when i go into front view or side view the model skin and clothes seem to go semi transparent and blotchy like in the image provided. when looking at the model NOT in a direct way like diagonally the model looks sort of ok, but there is still some weird visual glitch around its outer limits. Also weirdly the visual glitch seems to only affect material preview, but seems ok on render preview. I have tried many different options to see if i could locate the issue like setting the FBX option on the export panel to just mesh, and then as mesh and motion, also tried embedding textures and not embedding them, and then also deleting and undeleting hidden faces. Its all the same. Help!!
Posts: 23.1K,
Visits: 36.6K
Hi... Are you using the Blender Auto Setup tool? If not please see the thread below. This explains everything you need to know. https://forum.reallusion.com/475005/Blender-Auto-Setup
Wonder Nexus 3D
Wonder Nexus 3D
Visits: 110
Thank you for your message, i actually am already using the tool, and for the most part it works...until i press front view, and ive also realised its every view which is straight on, so side, from the back, top and bottom looking at an angle it looks fine. It appears to be some issue with the blend mode, setting it to alpha blend seems to work for the skin, but the teeth and eyes and clothes are still all terrible looking!
AutoDidact
AutoDidact
Posts: 2.1K,
Visits: 13.6K
Can you post a screenshot?
