How to remove eyebrow from an Elite Character?
Posted By jl6022 5 Years Ago
barca-8
barca-8
Posts: 218, Visits: 700
Just encountered this problem. Seems like it would be easier/cleaner if the default RL skin textures simply didn't include eyebrows.
It's a lot harder to remove things than it is to add them as a layer (or whatever).
yepkoo
yepkoo
Posts: 1.2K, Visits: 1.9K
Thanks Miles, I'll try this
MilesV
MilesV
Posts: 133, Visits: 2.2K
I was half asleep when I submitted this around 3 am. So, if something doesn't make sense or you need some clarification let me know.
Ok, so the key to this is a range mask that you get with SkinGen Premium.
Start with the default CC3+ Avatar > Activate the SkinGen Editor > Navigate to the Makeup Tab
Right-click on the Eyebrow layer > Hover over Merge Down > Click Current Material
https://forum.reallusion.com/uploads/images/766b5cde-d763-48f2-a4f6-6023.png
You'll then get a popup asking you what texture size you want to bake into the base texture. Here I choose the 2K texture and click ok.
https://forum.reallusion.com/uploads/images/ea33000a-9774-47f6-9562-7d72.png
Click OK on the second popup.
https://forum.reallusion.com/uploads/images/f40eb5d4-c686-4f04-b038-2541.png
You'll notice the Eyebrow layer has disappeared from the Makeup Editor and has now been baked into the base texture.
https://forum.reallusion.com/uploads/images/6fbde58c-56df-4d78-bec6-9e94.png
Using the Makeup & SFX pack
(If you don't have this pack scroll down to Using the Eyebrow Tool)
Now let's add the Curved Sparse eyebrows from the Makeup & SFX pack. This can be done by either double-clicking on the icon or by clicking and dragging it onto the avatar.
https://forum.reallusion.com/uploads/images/4f21b3d8-8447-4615-8de6-dc47.png
You'll now have a new Eyebrow layer in the Makeup Editor. Right-click on one of the hair textures and select Find Image File.
https://forum.reallusion.com/uploads/images/5d754d6f-1223-4d11-aeb4-ed3c.png
Windows File Explorer will open up to the texture location.
https://forum.reallusion.com/uploads/images/4a6ccb00-e75b-4665-bc85-4066.png
You'll then need to navigate to the following location:
...\Reallusion\Template\Character Creator 3 Template\Texture\SkinTextures\MakeUp\4_Range\SkinTool
https://forum.reallusion.com/uploads/images/50750abb-eff2-4280-8bd6-83fb.png
On the Eyebrow layer scroll down to the Replace Section > Check the Active Box > Click and drag the EyebrowTool_ReplaceMask into the Range slot.
https://forum.reallusion.com/uploads/images/6d10972c-48b8-42ac-a55c-1a98.png
(If you followed the steps above, you can skip this)
https://forum.reallusion.com/uploads/images/abade348-899c-4250-875f-1b9a.png
Replace the Texture Patterns with your eyebrow texture and then delete or replace the normal maps.
https://forum.reallusion.com/uploads/images/67145b4b-87c5-48bd-a72d-b70b.png
The rest applies to both of the above methods
On your eyebrow layer scroll down to the Replace section and change the Material settings as shown below:
https://forum.reallusion.com/uploads/images/23835685-80ff-4744-9353-44b0.png
Next click the color swatch > In the window that opens use the Pick Screen Color tool and match the eyebrow skin color as closely as you can to the surrounding skin. I used #c69b85.
https://forum.reallusion.com/uploads/images/ab1eb032-1c44-4579-b3db-59bc.png
Scroll down to the Noise section and check enable. Then change the Color settings as shown below:
https://forum.reallusion.com/uploads/images/3e546312-3cf7-404f-8bd7-ab73.png
Before:
After:
Just keep tweaking the settings until you get a result you're happy with.
If you don't want eyebrows simply delete the pattern textures, but only after you've finished adjusting the Replace and Noise settings as they will be grayed out as soon as you delete the pattern textures.
https://forum.reallusion.com/uploads/images/5231d26b-21ea-468c-9d6d-968f.png
https://forum.reallusion.com/uploads/images/1cc248d3-6820-4aea-9980-c0cb.png
    yepkoo
    yepkoo
    I would definitely like to know.
    I cannot delete the hair, beard and eyebrows of the characters I created with Headshot.
    I don't want to mess with Photoshop.
    Posts: 15.8K, Visits: 31.4K
    Miles, I would be interested to know this as well, as I'm not familiar with using SkinGen for this purpose.
    MilesV
    MilesV
    Do you have the premium version of SkinGen? If so, you can remove the eyebrows with SkinGen's tools. I've done it on a couple of characters. There is a RL webinar (lightside maybe?) where Kai had an issue with the eyebrows. I can't remember if he shows how to use the SkinGen tools to remove them or if I figured that out on my own.
    If you have SkinGen Premium and aren't able to figure out how to do it, let me know and I can put something together for you. I'll try to remember next time I'm on my CC3 machine.
    jl6022
    jl6022
    Junior Member (162 reputation)Junior Member (162 reputation)Junior Member (162 reputation)Junior Member (162 reputation)Junior Member (162 reputation)Junior Member (162 reputation)Junior Member (162 reputation)Junior Member (162 reputation)Junior Member (162 reputation)
    Posts: 3, Visits: 22
    Thank you so much!
    jl6022
    jl6022
    Thanks, but I just began to use this product two days ago.
    Posts: 5.7K, Visits: 26.5K
    jl6022 (11/27/2021)
    I based my character design on one of the Elite Characters (which are CC3 instead of CC3+, but I didn't know. It turned out that I couldn't remove the eyebrow when applying make-up. PLEASE give a reminder that "it's not CC3+" for future users so they won't feel as tragic as I am).
    I really really don't want to re-do everything from scratch. Is it possible to remove the eyebrow anyway?
    Thanks.
    How many reminders do you need?
    CC1:
    https://forum.reallusion.com/uploads/images/fa20a09a-6f6c-48c6-89c5-4b9f.png
    CC3:
    https://forum.reallusion.com/uploads/images/3e6138fa-5cc8-451b-8895-d55d.png
    CC3+:
    https://forum.reallusion.com/uploads/images/99969c7e-3083-4748-9fa2-88e4.png
    CC3+ Thumbnails:
    https://forum.reallusion.com/uploads/images/c6213101-747c-4d26-a47f-ed41.png
    Every character generation is well marked throughout the software.
    For many characters the eyebrows are part of the skin texture of the face; this is unrelated to whether it is a CC3 or CC3+ character. So you did not make a bad purchase that you should feel tragic about.
    In CC3, you can convert a CC3 to a CC3+ character, this will not change the texture, but it will make the newer features available.
    The presence of the eyebrows as part of the face texture does indeed pose an issue if you want to add eyebrows via make-up or as hair item. I usually adjust the shape so that the original eyebrows are covered. Another option is to edit the eyebrows out of the face texture, but that is not so straightforward.
    I mostly create characters using Headshot, in which case it's easy to edit the eyebrows in the original face texture.
    There may be better solutions, but I can't think of any off-hand.
