Import skinned clothing assets
Posted By Seki101 5 Years Ago
vidi
vidi
Posts: 10.8K, Visits: 40.2K
Is super easy
import your static clothmesh in CC , fit it on the Character and press the transfer skin weights button
liebe Grüße vidi
gicag14102
gicag14102
Posts: 49, Visits: 2.1K
Can you show copy weight to cc in your yt channel.
vidi
vidi
Actually that would  make not sence, because the clothmesh  must be follow and deform with the CC Character.
DAZ Character  has different skeleton. weightmaps are the influence areas of the meshdeform  from  corresponding bones.
For this reason,  you need copy the weights from CC to the Cloth otherwise you would get odd results.
liebe Grüße vidi
gicag14102
gicag14102
Can you copy daz cloth skinning into cc3 using Akeytsu.
Thanks
Seki101
Seki101
Junior Member (116 reputation)Junior Member (116 reputation)Junior Member (116 reputation)Junior Member (116 reputation)Junior Member (116 reputation)Junior Member (116 reputation)Junior Member (116 reputation)Junior Member (116 reputation)Junior Member (116 reputation)
Posts: 5, Visits: 17
I see.
Thank you so much vidi!
Seki101
Seki101
I see.
vidi
vidi
No
you can make any conform in this case
Important if you use Maya,  in the export setting must version FBX 2012 set otherwise you get a error message
liebe Grüße vidi
vidi
vidi
No
liebe Grüße vidi
Seki101
Seki101
Thank you vidi!
Are there any requirements for import Cloth, Hair Acc with FBXKey?
like mesh name has to stay the same or the topology has to be exactly the same...etc
vidi
vidi
If the Cloth is skinned with a FBXkey CC Base
you need to use  in CC the import function Create> Cloth,Hair Acc with FBXKey
otherwise there are no other way
btw I prefer also this way, because I'm not realy happy with the skinning tools in CC
I skin my mesh in Akeytsu now, because no subscription mode.
My workflow  I import my static cloth mesh, use in CC the copy skin method and export this as FBX. The FBX key will generate automatically. This is a good starting point
I load my Meshes in Akeytsu and fine-tuning the weight maps.  At the end, I import all how describe above.
liebe Grüße vidi
