Transform multiple keyframes at same time
Posted By info.right2freedom 5 Years Ago
info.right2freedom
info.right2freedom
Junior Member (146 reputation)Junior Member (146 reputation)Junior Member (146 reputation)Junior Member (146 reputation)Junior Member (146 reputation)Junior Member (146 reputation)Junior Member (146 reputation)Junior Member (146 reputation)Junior Member (146 reputation)
Posts: 5, Visits: 52
I made a motion which I added to my character, later I created a bouncing transform with keyframes,
but now I realized I need to increase my character and also bring it forward on X axes.
I didn't found any solution to do this without editing every single keyframe.
Is it a possible to create a group form it and add new transform value on top of it (as pre-compose in After Effect)?
I even tried to create action with collect clip from the transform keyframes but it doesn't working,
I saw a tutorial when it was done on a prop in the prop key editor but not on a character.
Also is there a possibility to save the whole character transform (not just the 2D motion key editor) value into a motion? Because when I import it to my character it does nothing.
I would appreciate if somebody will help me to solve this issue of mine.
kylelee
kylelee
Posts: 462, Visits: 4.2K
info.right2freedom (11/19/2021)
Hi, I have recorded a video to explain how can I do that.
I use 2D Motion Key Editor to set my keyframe.
After my motion setting is done, I will set my Transform Key.
kylelee
kylelee
You also can adjust all keyframes by multi-selecting.
Multi-selecting: Ctrl + Drag
Here are my operations.
info.right2freedom
info.right2freedom
Thank you very much for your time and effort, unfortunately your tutorials didnt answered my problem, probably it is my fault I didnt explain it correctly
But I saw something very interesting in your shorter tutorial when you capture all the keyframes and you scale them, do you need to press any specific keyboard shortcut to do this???
I explained in my short tutorial what is my problem please take a look:
https://www.loom.com/share/d2ea060aeef54e00bac4af183c922b2d
