Miranda (RL)
Miranda (RL)
Posts: 1.8K,
Visits: 11.2K
Hi everyone, Character Creator is updated to version 3.44 with the following updates: - Added: Compatibility with CC Omniverse Connector v3.44. >> Know More
- Enhanced: Optimized Restore Project order of operation: When the saved project is designated for restore, the process will run from start to finish without interruption from pop-up messages.
- Enhanced: Export FBX menu sections are now collpasible, which makes it easier to find the checkbox settings lying at the bottom of the menu, e.g. Delete Hidden Faces option.
- Enhanced: Export FBX > Blender Preset will now export JSON files.
- Fixed: Saved projects not appearing in the File > Recent Projects list.
- Fixed: Application crash as a result of renaming materials for objects that share the same mesh name and that have undergone Consolidate Material. (FT #7863, reported by c68)
- Fixed: Characters that have undergone Modify > Remove SkinGen Data have their texture sizes influenced by Export Settings > Max Texture Size settings. (FT# 7817, reported by 4u2ges)
Reallusion Team
Last Active: 4 hours ago
Posts: 5.7K,
Thank you for the continued work on this version.
Miranda (RL)
Miranda (RL)
Posts: 1.8K,
Visits: 11.2K
Hi everyone, Version 3.44 was updated from v3.44.4702.1 to v3.44.4709.1 with the following changes: - Fixed: CC crashes when applying certain characters from the smart Gallery, i.e. Scan Reality_Natasha.ccAvatar. (FT #8213, FT #8210)
- Fixed: Moving the morph slider for characters process with Create Head & Body Morph Sliders, causes the eyeballs and teeth to displace. In order to solve this issue, you'll need to reapply Create Head & Body Morph Sliders. (FT #8307)
- Fixed: Exporting Game Base Characters in USD format results in a loss of animation, reset of character position, with offset to the hair and eyeballs. (Reference to this image, posted on this post)
Reallusion Team
