Timeline Issues
Posted By shotty_858434 4 Years Ago
shotty_858434
shotty_858434
Veteran Member (544 reputation)Veteran Member (544 reputation)Veteran Member (544 reputation)Veteran Member (544 reputation)Veteran Member (544 reputation)Veteran Member (544 reputation)Veteran Member (544 reputation)Veteran Member (544 reputation)Veteran Member (544 reputation)
Posts: 32, Visits: 132
Thank you. That makes a big difference
Last Active: 4 Months Ago
Posts: 5.7K, Visits: 26.5K
From your description it seems that the Timeline was not at frame 1 when you added/adjusted assets to your scene.
If you start to make any changes to an added asset at any point other that frame 1 then that asset will have keyframes added to the Timeline. This means that said asset will start animating from the frame 1 position up to the keyframe position added when adjusted.
You can correct this by making sure that the Timeline scrubber is at frame 1 in your present scene, from the menu bar select "Animation > Remove Scene Animation and choose one of the options shown below.
https://forum.reallusion.com/uploads/images/3eed98ff-bfdc-41e7-96d3-a995.png
shotty_858434
shotty_858434
I am trying to set up a small scene.
When I press play, all of my props that attached to my character start flying around. Other characters start floating, also.
Is there a recommended tutorial that explains the details of the timeline?
