Is there a way to 'remember' a camera position?
Posted By Vektorsoft 4 Years Ago
Vektorsoft
Vektorsoft
Senior Member (309 reputation)Senior Member (309 reputation)Senior Member (309 reputation)Senior Member (309 reputation)Senior Member (309 reputation)Senior Member (309 reputation)Senior Member (309 reputation)Senior Member (309 reputation)Senior Member (309 reputation)
Posts: 19, Visits: 78
I'm working in a model, and I would like always to return to the same camera view, to see how it looks.
Something similar to push the 'K' key, but customized.
Does it make sense?
Is that possible?
Thank you
Last Active: 4 days ago
Posts: 15.8K, Visits: 31.3K
Vektorsoft (10/11/2021)
Does it make sense?
Is that possible?
Thank you
The easiest way is to add a camera with that view and the check lock camera (I'm not in front of iClone so I don't know the exact term).
You would then use the Preview camera to move around your model as needed after which you select the camera you added for your static view.
It would be useful to have an Aux Camera for that purpose as Poser does, but my suggestion is the best we can do.
BTW, you can also save a specific camera position.
Vektorsoft
Vektorsoft
I'm using only CC3, is that feature available in this software?
Last Active: 5 days ago
Posts: 5.7K, Visits: 26.5K
In CC3 there is no direct way to add a camera and then switch between that one and another.
There is a workaround, not very elegant but usable. Set your scene up exactly as you want it to be. In the Content manager tab navigate to "Stage Elements" > Camera > Custom. Click on the + at the lower part of the panel  This will add you camera setup to this folder, just make sure to give it a meaningful name for reuse. You can now reposition your camera as often as you need and save each setup under a different name. Now you can navigate around the scene to make adjustments to the character and return to one of your saved camera settings for rendering, or whatever.
76% of original size (was 661x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/c540723c-2a19-4924-9000-4179.png
If anything isn't clear post your questions here. :cool::)
Vektorsoft (10/12/2021)
I'm sorry, I should read better...:blush:
Vektorsoft
Vektorsoft
Cool trick!!!!
Thank you for your help!
Vektorsoft
Vektorsoft
No problem!!! Thanks for your help anyway, maybe I would need Iclone after all.
