Vektorsoft (10/11/2021)
I'm working in a model, and I would like always to return to the same camera view, to see how it looks.
Something similar to push the 'K' key, but customized.
Does it make sense?
Is that possible?
Thank you
The easiest way is to add a camera with that view and the check lock camera (I'm not in front of iClone so I don't know the exact term).
You would then use the Preview camera to move around your model as needed after which you select the camera you added for your static view.
It would be useful to have an Aux Camera for that purpose as Poser does, but my suggestion is the best we can do.
BTW, you can also save a specific camera position.
3 Years Ago by
