API for manipulating MotionPlus animations?
Posted By michael.davey 4 Years Ago
michael.davey
michael.davey
New Member (30 reputation)New Member (30 reputation)New Member (30 reputation)New Member (30 reputation)New Member (30 reputation)New Member (30 reputation)New Member (30 reputation)New Member (30 reputation)New Member (30 reputation)
Posts: 1, Visits: 23
Hi,
We're using the python plugin functionality to build animation sequencies.  So far, we’ve got a “hello world” project that does this, but we haven’t yet been able to work out how to:
  • Move the PlayHead to an arbitrary timeline position
  • Determine how long an animation is, so that we can move the PlayHead to just after the previous animation for the next animation
  • Programmatically stretch or shrink an animation
Does this make sense?  Is anyone able to offer any pointers on how to achieve these?
E.g.
import math, RLPy
import os
import winreg
import PySide2
from PySide2 import *
from PySide2.shiboken2 import wrapInstance
play_length = 30000
#play_length = 5000
def initialize_plugin():
    # Add menu
    ic_dlg = wrapInstance(int(RLPy.RUi.GetMainWindow()), QtWidgets.QMainWindow)
    plugin_menu = ic_dlg.menuBar().findChild(QtWidgets.QMenu, "pysample_menu")
    if (plugin_menu == None):
        plugin_menu = wrapInstance(int(RLPy.RUi.AddMenu("Python Samples"RLPy.EMenu_Plugins)), QtWidgets.QMenu)
        plugin_menu.setObjectName("pysample_menu")
    hello_world_action = plugin_menu.addAction("Hello World")
    hello_world_action.triggered.connect(do_work)
def do_work():
    #-- Get Characters from current scene --#
    avatar_list = RLPy.RScene.GetAvatars()
    #-- Get First Character --#
    avatar = avatar_list[0]
    # Clear all annimations
    RLPy.RGlobal.RemoveAllAnimations( avatar )
    #-- Get Skin Bone Data --#
    skin_bone = avatar.GetSkeletonComponent().GetSkinBones()
    #-- Get Motion Bone Data --#
    motion_bone = avatar.GetSkeletonComponent().GetMotionBones()
    #-- Get First Clip --#
    animation_clip = avatar.GetSkeletonComponent().GetClip(0)
    #-- Extend the Clip length --#
    animation_clip.SetLength(RLPy.RTime(play_length))
    do_work1(animation_clip, motion_bone)
    load_motionplus(avatar)
    RLPy.RGlobal.Play(RLPy.RTime(0), RLPy.RTime(play_length))
def do_work1(animation_clip, motion_bone):
    #-- Find head bone --#
    for bone in motion_bone:
        if bone.GetName() == "RL_Head":
            print("found head")
            #-- Get Key from Layer --#
            head_control = animation_clip.GetControl("Layer", bone)
            data_block = head_control.GetDataBlock()
            float_control_rotate_x = data_block.GetControl("Rotation/RotationX")
            #-- Set Key in current time to rotate the head bone to 90 degree --#
            float_control_rotate_x.SetValue(RLPy.RTime(0), math.radians(0))
            float_control_rotate_x.SetValue(RLPy.RTime(500), math.radians(90))
            print("done")
def load_motionplus(avatar):
    # Get the iClone 7 default template path
    registry = winreg.ConnectRegistry(None, winreg.HKEY_LOCAL_MACHINE)
    rawKey = winreg.OpenKey(registry, r"SOFTWARE\Reallusion\iClone\7.0")
    ic_template_path = os.path.abspath(
        winreg.QueryValueEx(rawKey, "Template Data")[0])
    RLPy.RGlobal.SetTime(RLPy.RTime(1000))
    # Load Box_001.iProp
    RLPy.RFileIO.LoadFile(
        ic_template_path + "//iClone Template//MotionPlus//Female//Heidi_Talk 1.iMotionplus")
    RLPy.RGlobal.SetTime(RLPy.RTime(25500))
        ic_template_path + "//iClone Template//MotionPlus//Female//Heidi_Talk 2.iMotionplus")
 do_work()
