Making a music video -- is there a way to play the music AND record facial animations using motion...
Posted By jfjs75 4 Years Ago
Making a music video -- is there a way to play the music AND record...
OldschoolAnimator
OldschoolAnimator
Veteran Member (575 reputation)Veteran Member (575 reputation)Veteran Member (575 reputation)Veteran Member (575 reputation)Veteran Member (575 reputation)Veteran Member (575 reputation)Veteran Member (575 reputation)Veteran Member (575 reputation)Veteran Member (575 reputation)
Posts: 47, Visits: 818
I'm doing something similar with my project. What I do is have something like audacity playing the voice clip in the background while cartoon animator 4 is setup to record.  You might have to use headphones for this.  I just set cartoon animator 4 for 1500 frames in the project window and then when the appropriate point comes up on the music, hit record. Later I'll go back in trim the animstion and drop in the audio to my animation, adjust the timing and then save that project with the audio embedded.
jfjs75
jfjs75
Junior Member (190 reputation)Junior Member (190 reputation)Junior Member (190 reputation)Junior Member (190 reputation)Junior Member (190 reputation)Junior Member (190 reputation)Junior Member (190 reputation)Junior Member (190 reputation)Junior Member (190 reputation)
Posts: 7, Visits: 24
Basically the title... I'm trying to find a way to make a music video with this program.  The one hurdle I'm hitting is wanting to record the face in time to the music -- I've got the motion live facial mocap plugin, but when I try to record, it turns the music off, so I can't time the recording.
I know I can use the automatic lip syncing, but i don't have just the vocals, so it tries to sync the lips to the music, not the vocals, which is frustrating.
Thanks!
