gondarmail
gondarmail
Visits: 77
Hello folks.... Most fbx downloads contains two folders: Source and Textures. What is the best way to apply the textures? And with 3DXchange or directly on iClone 7? Thanks in advance....
Visits: 22.1K
Um, using my Python routine?
Am7add9
Am7add9
Visits: 9.3K
open folder. open iclone. drag textures to corresponding slots from folder. if you do not use something like 3d coat or substance painter experiment with textures from this location into metallic and/or roughness C:\Users\Public\Documents\Reallusion\Template\iClone 7 Template\iClone Template\Texture\Bump
there are online sites that will generate bump-ao-metatlic-roughness
gondarmail
gondarmail
Visits: 77
Thanks, the reason is that I find many 3d objects online, and they load without the textures. On the other hand some do loaf with the right textures / colors. What's the trick?
