Textures, how to?
https://forum.reallusion.com/Topic492250.aspx
Print Topic | Close Window
By gondarmail - 5 Years Ago
Hello folks....
Most fbx downloads contains two folders: Source and Textures.
What is the best way to apply the textures?
And with 3DXchange or directly on iClone 7?
Thanks in advance....
By Kelleytoons - 5 Years Ago
Um, using my Python routine?
By Am7add9 - 5 Years Ago
open folder.
open iclone.
drag textures to corresponding slots from folder.
if you do not use something like 3d coat or substance painter
experiment with textures from this location into metallic and/or roughness
C:\Users\Public\Documents\Reallusion\Template\iClone 7 Template\iClone Template\Texture\Bump
there are online sites that will generate bump-ao-metatlic-roughness
Thanks, the reason is that I find many 3d objects online, and they load without the textures.
On the other hand some do loaf with the right textures / colors.
What's the trick?
