Hi...
Are you using CrazyTalk Animator 3 or Cartoon Animator 4? I only ask because this is in the CTA3 forum which is more like an archive forum. You will normally get more replies if you post in the CTA4 forum.
To move the voice clip you just need to select it on the Voice Clip track of the timeline and then left click and drag it to where you want. So for example, if your voice clip currently starts at frame 1 you can drag it to frame 100 and it will begin playing at that point. And if you want to break the voice clip, just go to the frame number you wish and then right click the voice clip at this point and select Break. You can then move the two parts independently.
Note: When you move a voice clip all facial animation keys will move with it.
