Posts: 5.3K,
Visits: 16.8K
To complete the subject. There is even easier way to reload maps (without launching). Right mouse click on the map > Copy Right mouse click on the same map > Paste If it's bump map, prompt would popup to select map type.
Jeffster The Mighty
Jeffster The Mighty
Visits: 1.2K
Thanks so much for this. I tried it and it worked. I checked my files from 2018, which all work automatically. They have no maps folder. Just a .MTL file. When I launch the bump file, it's in an Iclone 7 temp folder. In any case, mystery solved.
Jeffster The Mighty
Jeffster The Mighty
Visits: 1.2K
We got it solved going forward. It's not the view mode. Quick mode doesn't affect the final render.
Posts: 5.3K,
Visits: 16.8K
Just FYI why you have a dirty look importing OBJ. It is a normal/bump and OBJ dilemma. Bump maps from OBJ are *always* loaded as normal type maps and never as bump by either iClone and 3DX. When you load bump maps manually you get prompted with normal/bump selection. But here you do not. It always normal regardless. And loading B/W bump map as more advanced normal map produces an ugly material effect. Depending on bump texture it sometimes may, but most of the time may not be tolerated. There is no solution other than reloading bump maps manually and selecting a bump type. Here is a quick demonstration: I wish though RL would prompt us to select bump maps type when loading a set/prop from OBJ (sets/props usually have one type of bump maps for all materials which is easy to identify).
Amper Sand
Amper Sand
Visits: 5.2K
To me it looks like a problem of iClone's view quality mode configuration (High, Medium, Qyick mode, custom...) What mode it is currently? You can check in Preferences menu, Quality section, maybe you changed there some parameters for the current mode you're using.
______________________________________________________________________________ Software developer. iClone hobbyist since January 11, 2020. Best work so far: Robots among us: The Lab and The sad end of a legend In progress: Black Mamba AMD Ryzen 3950X 16C/32T 4.2 GHz, 64GB RAM, RTX2080 11GB, 2TB Samsung 970 Pro SSD, 8TB Seagate BarraCuda HDD, Win11 64-bit, iClone 8.12
Visits: 22.1K
Actually, often iClone *will* note subobjects and offer to break them up from FBX files. It has more to do with the actual set in Daz (which is to say, how they are parented and such). You can get that effect in Daz by unparenting objects and/or changing Daz characters into props. If you have any particular item you'd like help with again, just let me know and I can show you how to do it.
Jeffster The Mighty
Jeffster The Mighty
Visits: 1.2K
Thanks for your suggestion. That saves me a headache this weekend.
Jeffster The Mighty
Jeffster The Mighty
Visits: 1.2K
Something has changed in DAZ. Either Daz or my settings. I just imported this chair, which I saved from Daz as a wavefront object file in 2018. It loads right into Iclone perfectly. Every object in that folder imports perfectly as an object. But FBX does solve the problem going forward. But OBJ files did work a few years ago. I would export characters as FBX and use all sorts of object files for my props. Fortunately, I have directories from 2018 with many objects in them, but I'll save my new stuff with FBX. I'll miss the usability of OBJs because Iclone will note any large number of meshes and offer to make them into subprops. It doesn't do that with FBX, and it's a pain in 3DXchange.
Visits: 22.1K
Okay, well that's your first problem. Export as an FBX (the preferred format) and drag and drop into iClone. It will bring it in with the diffuse maps correctly. Then apply my script to get all the other maps (and that link you supplied is VERY odd -- the "corridor" is a Poser file (PP2), not a Daz file, which is why I don't have it. But if you have a link to any Daz file I'll be glad to try it out for you).
Jeffster The Mighty
Jeffster The Mighty
Visits: 1.2K
I gave a link to the actual item. https://www.daz3d.com/generic-sci-fi-corridorBut again, it's any scene that I export from Daz as a wavefront .obj file. That's absolutely anything now.
