alerender
alerender
Visits: 289
Hello, when I try to pass an emotion to the character, I get this error .... Would anyone know the reason? Thanks
https://www.alerender.com/
Visits: 22.1K
I don't think that's a CC3+ avatar (required).
alerender
alerender
Visits: 289
Yes, I am using a cc3 avatar (I tried several) and I always get that message ....
Last Active: 4 Months Ago
Posts: 15.8K,
Visits: 31.4K
You need a CC3 + character, which is different and improved from regular CC3. Note the "+" (plus sign) in the type designation.
alerender
alerender
Visits: 289
It is that those are the ones that I am testing. Even if it is one that I import from CC3+. Look at the screenshot on the right
Posts: 15.8K,
Visits: 31.4K
OK, that should work. I haven't installed this yet, so I haven't tried. Except, there is one other setting; you need to enable ExPlus expressions for the character. That should already be the case for the built-ins, but just in case, this what you do:  1. At the Motion panel, click "Face Key". 2. At the Face Key / Muscle tab, select ExPlus from the drop-down. 3. If ExPlus has NOT been enabled yet for the character, a dialog will open. Click "Yes". Your character is now ExPlus enabled. If this doesn't work, I don't now...:unsure:
alerender
alerender
Visits: 289
Thank you very much for the reply. The problem is rare because it gives that error, but on the other hand the expression appears ...
michaelrbarton
michaelrbarton
Visits: 11.2K
I did not know this face animation existed. It works for me. I tried it on the same character and it worked. Did you try a different character? Maybe for some reason that character does not work for you.
alerender
alerender
Visits: 289
If I tried several and I don't know why it throws me that error ...
matthewsomeday127
matthewsomeday127
Visits: 52
Hey guys, even I know that's Katherine and she's THE CC3 and iClone queen. Her acculips work great......when they work at all. I've been having the same problem as of today, and believer me, Katherine, whom I've morphed into some magnificent creations, acculips's flawlessly, indeed almost miraculously, I'd say-------when it works. Natalie's also another one who works well. Below is merely one of the many related goofy messages I've gotten all day today. Hoping some genius will help us.
