father_356956 (5/14/2021)
thank you for the reply. So, there is an FBX file with the project. The structure and props load, but the textures and properties, such as transparent glass windows do not appear. Maybe I'm missing something?
FBX files come into two flavors.
The easiest is when all textures are embedded, this would be a rather large file. Depending on the object, it could be tens or 100s of MB.
The second option is when the FBX file only defines the mesh and the textures are referenced. In that case there should be an FBM folder. So for example, if the FBX file is TEST.FBX, there should be a TEST.FBM folder that contains the textures.
Unfortunately, iClone and/or 3DXchange don't always import all textures. Diffuse and Normal are there, but other ones need to be applied manually.
